Home » Eclipse Projects » EGit » UPgrading to JGit / EGit Release 1.3 (what should be done to upgrade to JGit/EGit Release 1.3 )
UPgrading to JGit / EGit Release 1.3 [message #803491] Tue, 21 February 2012 07:20 Go to next message
David Shwatrz is currently offline David Shwatrz
I have 1.1 version of EGIT
(In help->about eclipse-> Installation details I see version 1.1.0.2011...)
I saw that announcement of JGit / EGit Release 1.3
in egit-dev mailing list. (17 Feb 2012)
what should I do to update to 1.3 ? (it could be somehting standard in Eclipse
but I do not have much experience with updating sw with eclipse)
regards,
David Shwatrz
Re: UPgrading to JGit / EGit Release 1.3 [message #803601 is a reply to message #803491] Tue, 21 February 2012 09:59 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias Sohn
Try "Help > Check for Updates"
Re: UPgrading to JGit / EGit Release 1.3 [message #804042 is a reply to message #803601] Wed, 22 February 2012 00:52 Go to previous messageGo to next message
Thanks!
tried it, got :
"No updates were found".
Any ideas?
rgd,
David
Re: UPgrading to JGit / EGit Release 1.3 [message #804078 is a reply to message #804042] Wed, 22 February 2012 02:02 Go to previous messageGo to next message
Dariusz Luksza is currently offline Dariusz Luksza
Member
If you installed EGit from Marketplace, you need to go to:
Help -> Eclipse Marketplace -> Installed
and click on "Install" button beside EGit plugin.
Re: UPgrading to JGit / EGit Release 1.3 [message #804173 is a reply to message #804078] Wed, 22 February 2012 04:31 Go to previous message
If this also doesn't work, add the installation repo http://download.eclipse.org/egit/updates and try again "Help > Check for Updates"
Previous Topic:is HTTP authentication broken again?
Next Topic:Is there any way to track the duration of git clone operation
Current Time: Sat May 25 21:32:33 EDT 2013
Powered by FUDForum. Page generated in 0.01843 seconds
