Home » Eclipse Projects » Virgo » Virgo issue java.lang.OutOfMemoryError
Virgo issue java.lang.OutOfMemoryError [message #800856] Fri, 17 February 2012 10:55 Go to next message
Gabriel Afonso is currently offline Gabriel Afonso
I'm developing an OSGi application, and I put the bundles in Virgo. But I have a problem, when I put a lot of times this bundle in Virgo (5 times at lest) it trow a error and then it going down.
This is the error message:
java.lang.OutOfMemoryError: PermGen space
Dumping heap to /home/user/Virgo/virgo-tomcat-server-3.0.2.RELEASE/serviceability/heap_dump.hprof ...
Unable to create /home/user/Virgo/virgo-tomcat-server-3.0.2.RELEASE/serviceability/heap_dump.hprof: File exists
There are 8 bundles developing by me. 4 are normal bundles and the rest are WAB (Web application bundles). Also I'm using virgo Snaps.
What's happens? What am I doing wrong?
Re: Virgo issue java.lang.OutOfMemoryError [message #800857 is a reply to message #800856] Fri, 17 February 2012 10:59 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo Iliev
By "5 times" do you mean that you use the pickup folder to update your bundle during development?
Do you actually use IDE or just standalone Virgo (and pickup) from the console?
Re: Virgo issue java.lang.OutOfMemoryError [message #800860 is a reply to message #800857] Fri, 17 February 2012 11:01 Go to previous messageGo to next message
Right now I'm using the pickup folder in the virgo admin page to update my bundles.
Re: Virgo issue java.lang.OutOfMemoryError [message #800869 is a reply to message #800860] Fri, 17 February 2012 11:13 Go to previous message
If the OOM happens after several deployments this most probably means that some of the objects are left registered and kept in some structure (map, set, ...)
You can try to increase the VM's perm area size that holds class definitions. The VM parameter you need is -XX:MaxPermSize=<size>M. Change this in the Virgo's startup scripts or just set JAVA_OPTS environment variable.
The increased perm may solve the problem for a while but if the memory keeps growing then you'll need to check if there is some leak.
[Updated on: Fri, 17 February 2012 11:14]
Report message to a moderator
Previous Topic:How to read kernel dumps
Next Topic:Configure Tomcat to serve static files directly from filesystem
Current Time: Wed May 22 17:03:59 EDT 2013
Powered by FUDForum. Page generated in 0.06152 seconds
