Home » Eclipse Projects » Virgo » How to read kernel dumps
How to read kernel dumps [message #800848] Fri, 17 February 2012 10:46 Go to next message
Barbara Rosi-Schwartz is currently offline Barbara Rosi-Schwartz
Hello.
We are using a Virgo Kernel and therefore do not have access to the VWS Console. Any suggestions on how we could read the dumps the kernel generates?
TIA,
B.
Re: How to read kernel dumps [message #800849 is a reply to message #800848] Fri, 17 February 2012 10:48 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn Normington
In the past I've copied the dump directory across to a VWS instance (being careful to preserve the relative location) and then used the VWS console. Best to use the same release of VWS to match the VK release. Of course, you can also read some of the files, like the summary, using an editor.
Re: How to read kernel dumps [message #800852 is a reply to message #800849] Fri, 17 February 2012 10:50 Go to previous messageGo to next message
Note that we are working on a future feature of being able to run the VWS console on the kernel, which should help such scenarios. But the copying technique is a good stop-gap.
Re: How to read kernel dumps [message #800868 is a reply to message #800852] Fri, 17 February 2012 11:12 Go to previous message
Excellent, thank you, Glyn. I should have thought of the stop gap measure myself, actually!
Do you have an ETA on the future feature that enables the console on a kernel?
Previous Topic:Error w/Spring 3.1.0.RELEASE in repository/usr w/Virgo Tomcat 3.5.0.M02
Next Topic:Virgo issue java.lang.OutOfMemoryError
Current Time: Sun May 19 21:43:39 EDT 2013
Powered by FUDForum. Page generated in 0.11032 seconds
