Home » Modeling » EMF » [Teneo] Same flags in PersistanceOptions different outcome
[Teneo] Same flags in PersistanceOptions different outcome [message #797810] Mon, 13 February 2012 17:47 Go to next message
David Wynter is currently offline David Wynter
I used these same flags for a couple of years now
Properties props = new Properties();
props.setProperty(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH,
"28");
props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_KEY,
"true");
props.setProperty(PersistenceOptions.DEFAULT_ID_FEATURE_NAME,
"id");
props.setProperty(PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY, "simple");
props.setProperty(PersistenceOptions.JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS,
"false");
props.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "false");
props.setProperty(PersistenceOptions.DISABLE_ECONTAINER_MAPPING, "true");
props.setProperty(PersistenceOptions.ALWAYS_VERSION, "false");
props.setProperty(PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG,
"true");
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING,
"JOINED");
props.setProperty(PersistenceOptions.XSDDATE_CLASS,
"java.util.Date");
//ManyToOne and OneToMany are normally fetch eagerly, only if
you do SET_PROXY=true then these are set to lazy
props.setProperty(PersistenceOptions.SET_PROXY, "true");
But now I am getting a column E_ID instead of the one to one join I used
to get using this:
<xsd:complexType name="DerivativeIssueData">
<xsd:sequence minOccurs="0" maxOccurs="1">
<xsd:element ecore:opposite="derivativeIssueData" minOccurs="0"
maxOccurs="1" type="xsd:anyURI" name="instrument"
ecore:reference="mddbyam:Instrument">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@PrimaryKeyJoinColumn
@Column(name="instrument")</xsd:appinfo>
</xsd:annotation>
</xsd:element>
I have just added this and have several previous like it, they correctly
had the one to one between instrument and them. This does not? I cannot
see what is different? Any clues?
I added the @Column annotation, because the others came out with the
correct lowercase column name without it and this one comes out with an
upper case name, even after adding this annotation?
Thx.
David
Re: [Teneo] Same flags in PersistanceOptions different outcome [message #798130 is a reply to message #797810] Tue, 14 February 2012 04:28 Go to previous messageGo to next message
I am old and grey, memory going. I forgot to add the attribute decl with
the @Id, so it works fine now that that is there.
David
On 13/02/12 22:47, David Wynter wrote:
> props.setProperty(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH, "28");
> props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_KEY, "true");
> props.setProperty(PersistenceOptions.DEFAULT_ID_FEATURE_NAME, "id");
> "simple");
> "false");
> props.setProperty(PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG, "true");
> props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, "JOINED");
> props.setProperty(PersistenceOptions.XSDDATE_CLASS, "java.util.Date");
> //ManyToOne and OneToMany are normally fetch eagerly, only if you do
> to get using this:
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> Thx.
> David
Re: [Teneo] Same flags in PersistanceOptions different outcome [message #798317 is a reply to message #797810] Tue, 14 February 2012 09:24 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi David,
This could be a backward compatibility issue, from what version did you upgrade?
gr. Martin
On 02/13/2012 11:47 PM, David Wynter wrote:
> props.setProperty(PersistenceOptions.JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS, "false");
> //ManyToOne and OneToMany are normally fetch eagerly, only if you do SET_PROXY=true then these are set to lazy
> But now I am getting a column E_ID instead of the one to one join I used to get using this:
> <xsd:element ecore:opposite="derivativeIssueData" minOccurs="0" maxOccurs="1" type="xsd:anyURI" name="instrument"
> <xsd:annotation>
> <xsd:appinfo source="teneo.jpa">@PrimaryKeyJoinColumn @Column(name="instrument")</xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> I have just added this and have several previous like it, they correctly had the one to one between instrument and them.
> This does not? I cannot see what is different? Any clues?
> I added the @Column annotation, because the others came out with the correct lowercase column name without it and this
> one comes out with an upper case name, even after adding this annotation?
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Same flags in PersistanceOptions different outcome [message #798344 is a reply to message #798317] Tue, 14 February 2012 10:02 Go to previous message
I am old and grey to :-) as I did not look at the last 10 posts in the newsgroup, so I missed your own solution.
gr. Martin
On 02/14/2012 03:24 PM, Martin Taal wrote:
> Hi David,
> gr. Martin
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> Thx.
>> David
The Netherlands
Previous Topic:Binding: EMFProperties.list() with FeaturePath - Bug ?
Next Topic:[CDO] Performance Issues on loading large amount of data
Current Time: Sun May 19 19:39:58 EDT 2013
Powered by FUDForum. Page generated in 0.02967 seconds
