Home » Eclipse Projects » Equinox » SWT and Equinox product export problems(SWT produces class not found exceptions outside of eclipse)
SWT and Equinox product export problems [message #797726] Mon, 13 February 2012 16:03 Go to next message
Crypt Demon is currently offline Crypt Demon
Member
So I'm making a plugin project that uses SWT for the gui and declarative services for loading the gui service up.
My application launches fine with the run configuration I use in eclipse. The gui starts up and we all dance and sing. However, whenever I make a product definition from this runtime config and export it, the gui won't start and the OSGI console throws me NoClassDefFoundError whenever it hits an import for anything in the SWT libraries.
I made a very simple project to demonstrate this behavior. All it does is load up a window with some text in a control. Works fine when I run from the eclipse environment, and then doesn't when I run it after I export
What I've noticed is that when running from eclipse, the platform specific swt bundle fragment shows as resolved. It also tells me that the generic swt bundle has a fragment bundle associate with it. However, the osgi console only shows that it's installed when run from the executable.
Run From Eclipse Environment:
id	State       Bundle
0	ACTIVE      org.eclipse.osgi_3.5.2.R35x_v20100126
1	ACTIVE      org.eclipse.osgi.services_3.2.0.v20090520-1800
2	ACTIVE      org.eclipse.equinox.common_3.5.1.R35x_v20090807-1100
4	ACTIVE      org.eclipse.swt_3.5.2.v3557f
	            Fragments=5
5	RESOLVED    org.eclipse.swt.gtk.linux.x86_64_3.5.2.v3557f
	            Master=4
6	ACTIVE      org.eclipse.equinox.ds_1.1.1.R35x_v20090806
7	ACTIVE      org.eclipse.equinox.util_1.0.100.v20090520-1800
8	ACTIVE      com.mnet.uiTest_1.0.0.qualifier
9	INSTALLED   org.eclipse.swt.win32.win32.x86_3.5.2.v3557f
10	INSTALLED   org.eclipse.swt.win32.win32.x86_64_3.5.2.v3557f
11	INSTALLED   org.eclipse.swt.wpf.win32.x86_3.5.2.v3557f
Run From exported product:
id	State       Bundle
1	ACTIVE      com.mnet.uiTest_1.0.0.201202131522
3	ACTIVE      org.eclipse.equinox.ds_1.1.1.R35x_v20090806
4	ACTIVE      org.eclipse.equinox.util_1.0.100.v20090520-1800
5	RESOLVED    org.eclipse.osgi.services_3.2.0.v20090520-1800
6	ACTIVE      org.eclipse.swt_3.5.2.v3557f
7	INSTALLED   org.eclipse.swt.gtk.linux.x86_64_3.5.2.v3557f
Here is my product definition:
<?pde version="3.5"?>
<product application="org.eclipse.ui.ide.workbench" useFeatures="false" includeLaunchers="true">
   <configIni use="default">
   </configIni>
   <launcherArgs>
      <programArgs>-os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl ${target.nl} -console</programArgs>
      <vmArgs>-Declipse.ignoreApp=true -Dosgi.noShutdown=true -Dequinox.ds.print=true</vmArgs>
      <vmArgsMac>-XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts</vmArgsMac>
   </launcherArgs>
   <launcher name="test">
      <solaris/>
      <win useIco="false">
         <bmp/>
      </win>
   </launcher>
   <vm>
   </vm>
   <plugins>
      <plugin id="com.mnet.uiTest"/>
      <plugin id="org.eclipse.equinox.common"/>
      <plugin id="org.eclipse.equinox.ds"/>
      <plugin id="org.eclipse.equinox.util"/>
      <plugin id="org.eclipse.osgi"/>
      <plugin id="org.eclipse.osgi.services"/>
      <plugin id="org.eclipse.swt"/>
      <plugin id="org.eclipse.swt.gtk.linux.x86_64" fragment="true"/>
      <plugin id="org.eclipse.swt.win32.win32.x86" fragment="true"/>
      <plugin id="org.eclipse.swt.win32.win32.x86_64" fragment="true"/>
      <plugin id="org.eclipse.swt.wpf.win32.x86" fragment="true"/>
   </plugins>
   <configurations>
      <plugin id="com.mnet.uiTest" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="2" />
      <plugin id="org.eclipse.equinox.ds" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.osgi" autoStart="true" startLevel="-1" />
      <plugin id="org.eclipse.swt" autoStart="true" startLevel="0" />
   </configurations>
</product>
Manifest for ui bundle:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: UiTest
Bundle-SymbolicName: com.mnet.uiTest
Bundle-Version: 1.0.0.qualifier
Bundle-Vendor: MNET
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Service-Component: OSGI-INF/component.xml
Import-Package: org.eclipse.swt,
 org.eclipse.swt.widgets
Export-Package: com.mnet.uiTest
Component Definition for ui bundle:
<scr:component xmlns:scr="no links allowed" activate="startup" deactivate="shutdown" immediate="true" name="com.mnet.uiTest">
   <implementation class="com.mnet.uiTest.UITest"/>
   <service>
      <provide interface="com.mnet.uiTest.UITest"/>
   </service>
</scr:component>
GUI Class Code:
package com.mnet.uiTest;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class UITest implements Runnable	{
	private Display display;
	private boolean isRunning;
	private Text txtWindow;
	public void run(){
		display = new Display();
		Shell myShell = new Shell(display);
		myShell.setSize(600, 600);
		txtWindow = new Text(myShell, SWT.MULTI | SWT.V_SCROLL);
		txtWindow.setText("Starting");
		txtWindow.setSize(200, 200);
		myShell.open();
		runDisplayEventQueue();
	private void runDisplayEventQueue() {
		isRunning = true;
		while (isRunning && !display.isDisposed())
			try {
				if (!display.readAndDispatch())
					display.sleep();
			} catch (Throwable t) {
				t.printStackTrace();
		isRunning = false;
		display.dispose();
		shutdown();
	public void startup() {
		System.out.println("Starting GUI");
		new Thread
		(this).start();
	public void shutdown() {
		System.out.println("shutting down gui");
		if(isRunning)
			display.syncExec( new Runnable() {  public void run() { display.dispose();} });
Re: SWT and Equinox product export problems [message #797734 is a reply to message #797726] Mon, 13 February 2012 16:12 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
In the export there's only the linux-swt fragment. On which OS are you
running?
Tom
Am 13.02.12 22:03, schrieb Missing name Mising name:
> libraries.
> the executable.
> id State Bundle
> Fragments=5
> Master=4
> id State Bundle
> </configIni>
> <launcherArgs>
> </launcherArgs>
> <solaris/>
> <bmp/>
> </win>
> </launcher>
> <vm>
> </vm>
> <plugins>
> </plugins>
> <configurations>
> startLevel="2" />
> </configurations>
> </product>
> Bundle-Name: UiTest
> Bundle-Vendor: MNET
> <service>
> </service>
> </scr:component>
> GUI Class Code:
> import org.eclipse.swt.widgets.Display;
> @Override
> public void run(){
> myShell.open();
> isRunning = true;
> try {
> display.sleep();
> isRunning = false;
> display.dispose();
> shutdown();
> new Thread
> (this).start(); }
> if(isRunning)
Re: SWT and Equinox product export problems [message #797739 is a reply to message #797734] Mon, 13 February 2012 16:22 Go to previous messageGo to next message
Member
I'm on Ubuntu Linux 64-bit. I've exported both for 64-bit linux and 32 bit windows with the proper fragments and get the same error on both platforms.
Re: SWT and Equinox product export problems [message #797742 is a reply to message #797734] Mon, 13 February 2012 16:23 Go to previous messageGo to next message
.... and how do you start the application? The swt-fragments use filters
Eclipse-PlatformFilter (-os, -ws and -arch) which are passed in eclipse.
Tom
Am 13.02.12 22:12, schrieb Tom Schindl:
> running?
> Tom
>> libraries.
>> the executable.
>> id State Bundle
>> Fragments=5
>> Master=4
>> id State Bundle
>> <?xml version="1.0" encoding="UTF-8"?>
>> </configIni>
>> <launcherArgs>
>> </launcherArgs>
>> <solaris/>
>> <bmp/>
>> </win>
>> </launcher>
>> <vm>
>> </vm>
>> <plugins>
>> </plugins>
>> <configurations>
>> startLevel="2" />
>> </configurations>
>> </product>
>> Bundle-Name: UiTest
>> Bundle-Vendor: MNET
>> <service>
>> </service>
>> </scr:component>
>> GUI Class Code:
>> @Override
>> public void run(){
>> myShell.open();
>> isRunning = true;
>> try {
>> display.sleep();
>> isRunning = false;
>> display.dispose();
>> shutdown();
>> new Thread
>> (this).start(); }
>> if(isRunning)
Re: SWT and Equinox product export problems [message #797746 is a reply to message #797739] Mon, 13 February 2012 16:26 Go to previous messageGo to next message
the problem is that the
Am 13.02.12 22:22, schrieb Missing name Mising name:
> platforms.
fragment is only installed but should be resolved. Like asked in the
other reply how do you launch it?
Tom
Re: SWT and Equinox product export problems [message #797747 is a reply to message #797746] Mon, 13 February 2012 16:29 Go to previous messageGo to next message
I think you should change:
to
<programArgs>-console</programArgs>
the ${things} are only defined inside eclipse!
Tom
Am 13.02.12 22:26, schrieb Tom Schindl:
>> platforms.
> Tom
Re: SWT and Equinox product export problems [message #797748 is a reply to message #797742] Mon, 13 February 2012 16:32 Go to previous messageGo to next message
Member
For starting, I just run the eclipse generated launcher executable that's made whenever you export a product configuration.
[Updated on: Mon, 13 February 2012 16:36]
Report message to a moderator
Re: SWT and Equinox product export problems [message #797756 is a reply to message #797747] Mon, 13 February 2012 16:39 Go to previous message
Member
That worked. Thanks a lot guys.
Tom Schindl wrote on Mon, 13 February 2012 16:29
to
Tom
Previous Topic:Some questions about java web start
Next Topic:p2 update mechanism broken after migrating to Helios
Current Time: Wed May 22 20:00:19 EDT 2013
Powered by FUDForum. Page generated in 0.06814 seconds
