| Re: Relative Path to JDBC-Url [message #797421 is a reply to message #721772] |
Mon, 13 February 2012 08:17  |
Glenn Williams Messages: 1 Registered: February 2012 |
Junior Member |
This is what I use on Windows to accomplish something similar to what you are after:
persistence.xml
<properties>
<property name="javax.persistence.jdbc.driver" value="org.apache.derby.jdbc.EmbeddedDriver" />
<property name="javax.persistence.jdbc.url" value="jdbc:derby:myDB;create=true" />
<property name="javax.persistence.jdbc.user" value="user" />
<property name="javax.persistence.jdbc.password" value="password" />
<property name="eclipselink.logging.level" value="FINE"/>
</properties>
Java Code
System.setProperty("derby.system.home", System.getProperty("user.home"));
database access code
The database access code will use the Derby database 'myDB' in the user's home directory.
Hope that helps!
Glenn
FUDForum. Page generated in 0.01783 seconds
