Home » Eclipse Projects » Eclipse 4 » How to access the osgi console for the application
How to access the osgi console for the application [message #795416] Fri, 10 February 2012 08:07 Go to next message
Karl Weber is currently offline Karl Weber
Member
I am using 4.2M5-I20120209. If I select the Host OSGi console, I get the message
WARNING: This console is connected to the current running instance of Eclipse!osgi>
Using, e.g. the command ss, I get the listing for the running ide, not the listing for my running e4 rcp application (started from within the ide), as was the case with 4.1. How can I access the osgi prompt for my application?
Re: How to access the osgi console for the application [message #795719 is a reply to message #795416] Fri, 10 February 2012 16:09 Go to previous message
Member
O.k., things have changed from 4.1.1 to 4.2M5. Once I added the org.eclipse.equinox.console plug-in and the other bundles described here the console for the application worked as well...
Previous Topic:Discouraged Access
Next Topic:ModelService.find cannot find part stacks
Current Time: Thu May 23 06:12:38 EDT 2013
Powered by FUDForum. Page generated in 0.01628 seconds
