Home » Modeling » EMF » [Teneo] Custom SQL Naming Strategy(Custom SQL Naming strategy is not called for FOREIGN KEY INDEX NAME)
[Teneo] Custom SQL Naming Strategy [message #795169] Fri, 10 February 2012 01:34 Go to next message
R Deepak is currently offline R Deepak
Thanks for Teneo!
I am using 1.2.0.v201107080556 and have a small issue. I have implemented a custom SQL Naming strategy where I remap and shorten table and column names.
I have extended ClassicSQLNameStrategy and overridden all the methods to including the convert method.
This method gets called for all SQL names other than the name for the FOREIGN KEY INDEX NAME.
I have set PersistenceOptions.ADD_INDEX_FOR_FOREIGN_KEY to "true".
If I set it to false, I have no problems. But I need the index.
Is this a bug or am I missing something?
Deepak
[Updated on: Fri, 10 February 2012 01:35]
Report message to a moderator
Re: [Teneo] Custom SQL Naming Strategy [message #795296 is a reply to message #795169] Fri, 10 February 2012 04:50 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Deepak,
A missing feature it is! Can you enter a bugzilla for it? I can probably take care of it in a short time (few days).
gr. Martin
On 02/10/2012 07:34 AM, R Deepak wrote:
> Thanks for Teneo!
> I have a small issue. I have implemented a custom SQL Naming strategy where I remap and shorten table and column names.
> Thanks
> Deepak
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Custom SQL Naming Strategy [message #795327 is a reply to message #795296] Fri, 10 February 2012 05:31 Go to previous message
Hi Martin,
I've filed the bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=371195
Previous Topic:Problems with Containment and EStores
Next Topic:[GWT] generated Editor fails to compile and execute
Current Time: Sun May 19 08:50:14 EDT 2013
Powered by FUDForum. Page generated in 0.01663 seconds
