Home » Eclipse Projects » Equinox » Problems start own Bundle in Eclipse
Problems start own Bundle in Eclipse [message #794489] Thu, 09 February 2012 06:04
Karl-Heinz Supen is currently offline Karl-Heinz Supen
Hello Forum,
when I try to run a own bundle in eclipse I got many errors and warning like:
org.osgi.framework.BundleException: Exception in org.eclipse.mylyn.internal.monitor.ui.MonitorUiPlugin.start() of bundle org.eclipse.mylyn.monitor.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
And warnings like:
!ENTRY org.eclipse.update.configurator 4 0 2012-02-09 11:14:15.072
!MESSAGE Could not install bundle plugins/ch.qos.logback.classic_0.9.27.v20110224-1110.jar Bundle "ch.qos.logback.classic" version "0.9.27.v20110224-1110" has already been installed from: reference:file:/C:/Programme/eclipse-java-indigo/eclipse/plugins/ch.qos.logback.classic_0.9.27.v20110224-1110.jar
I think the reason is a wrong bundle configuration. But where can I configure that only the bundles of my project should run?
My system is a windows xp maschine with eclipse indigo.
Thank you very much.
Karl-Heinz
Previous Topic:Dynamically extendable Equinox application
Next Topic:Some questions about java web start
Current Time: Fri May 24 12:31:04 EDT 2013
Powered by FUDForum. Page generated in 0.01557 seconds
