Home » Newcomers » Newcomers » Non Functional Requirement (NFR)(I need to detect and separate the non functional requirement in any component of Eclipse.)
Non Functional Requirement (NFR) [message #794243] Wed, 08 February 2012 22:49 Go to next message
Komail-si Mashhadi is currently offline Komail-si Mashhadi
Hello Dears,
My PhD project is tracing the Non Functional Requirements(NFR), and I want to work on Eclipse component as a case study. Therefore, I need to know that is there any way to get only the information of NFRs from Eclipse project? If they are not separate from the other requirements, how you recognize and separate NFRs? Is there any way to detect and separate the NFRs from a lot of requirements and sent requests of Eclipse?
Re: Non Functional Requirement (NFR) [message #795236 is a reply to message #794243] Fri, 10 February 2012 03:27 Go to previous messageGo to next message
Hello again dears
I'm waiting for you help. It is so important for me. If I don't find a way for gathering the data about NFRs I have to change my topic.
Please guide me as soon as you can.
thank you.
[Updated on: Sat, 11 February 2012 21:46]
Report message to a moderator
Re: Non Functional Requirement (NFR) [message #800843 is a reply to message #795236] Fri, 17 February 2012 10:39 Go to previous message
Wayne Beaton is currently offline Wayne Beaton
Try starting in the wiki.
I did a quick search on "nonfunctional" and came up with a couple of hits. That may give you a starting point.
http://wiki.eclipse.org/Special:Search?search=nonfunctional&go=Go
http://wiki.eclipse.org/Special:Search?search=%22non+functional%22&go=Go
If the first hit looks promising, you might try engaging directly with the SMILA project to see if they can help.
http://www.eclipse.org/projects/project.php?id=rt.smila
HTH,
Wayne
Previous Topic:Updating eclipse 3.7.1
Next Topic:wow
Current Time: Sat May 18 06:55:10 EDT 2013
Powered by FUDForum. Page generated in 0.01605 seconds
