Home » Language IDEs » AJDT » AJDT is not working in eclipse
AJDT is not working in eclipse [message #793854] Wed, 08 February 2012 12:09 Go to next message
shweta garg is currently offline shweta garg
I am a newbie with eclipse and AJDT both... Crying or Very Sad
Firstly I installed eclipse, and it is working f9. Since, I am working with 3.7.2 version of eclipse, so I downloaded "ajdt_2.1.3_for_eclipse_3.7. zip". Then UNZIPPED it and put it in plugin, features and dropins folder of eclipse.
Now when I am running my "Hello World" project (code is available with AJDT distribution), it is giving following error:
Exception in thread "main" java.lang.NoClassDefFoundError: helloworld/Hello
Caused by: java.lang.ClassNotFoundException: helloworld.Hello
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
Could not find the main class: helloworld.Hello. Program will exit.
According to me, either some package or link with package is missing or some path problem is there in eclilpse. Because java and aj files are getting built by command line but not with eclipse... Crying or Very Sad
I am attaching my eclipse SDK window with "Hello World example" here.
Kindly help me in this issue.
Re: AJDT is not working in eclipse [message #793897 is a reply to message #793854] Wed, 08 February 2012 13:23 Go to previous messageGo to next message
Andrew Eisenberg is currently offline Andrew Eisenberg
Do not use the drop-ins directory. Either install from the update site or follow the instructions on the downloads page:
http://www.eclipse.org/ajdt/downloads/
To install from a zip file, download the zip and point your p2 installer to that file. Then proceed as if it were a normal update site. Do not unzip the update site into the dropins directory.
Re: AJDT is not working in eclipse [message #793918 is a reply to message #793897] Wed, 08 February 2012 13:42 Go to previous messageGo to next message
Since I am a newbie, I dont know how to point p2 installer to that file.
Can you please explain me the full process, because I am trying this for a long time, but still not able to complete it successfully...
Re: AJDT is not working in eclipse [message #793925 is a reply to message #793918] Wed, 08 February 2012 13:51 Go to previous messageGo to next message
Best way to install:
1. Help -> Install new software
2. In the "Work with" text box, type: http://download.eclipse.org/tools/ajdt/37/update
3. press enter and wait for the contents to load
4. Check AJDT and click next and follow the instructions.
Re: AJDT is not working in eclipse [message #793932 is a reply to message #793925] Wed, 08 February 2012 14:00 Go to previous messageGo to next message
Thanx for the procedure...
But I have already tried this so many times, but after giving the specified url, it is giving me "Pending" even ater 1 hr also.
I have changed my proxy settings also correctly.
Kindly help me in this issue now.
Re: AJDT is not working in eclipse [message #793933 is a reply to message #793932] Wed, 08 February 2012 14:03 Go to previous messageGo to next message
Then, instead of using http://download.eclipse.org/tools/ajdt/37/update as the work with, click on the "add..." button next to the text box. Click on "Archive" and navigate to your downloaded AJDT zip. Use that update site and follow with step 3.
Re: AJDT is not working in eclipse [message #793941 is a reply to message #793933] Wed, 08 February 2012 14:09 Go to previous messageGo to next message
On following above procedure, after step 3, "next" tab is not getting activated and it is saying "All items are installed".
Re: AJDT is not working in eclipse [message #793950 is a reply to message #793941] Wed, 08 February 2012 14:17 Go to previous messageGo to next message
You need to first clean out your drop-ins folder. But, at this point, things may be too messy in there and you may have to start with a new installation of Eclipse.
Re: AJDT is not working in eclipse [message #793974 is a reply to message #793950] Wed, 08 February 2012 14:49 Go to previous messageGo to next message
As you have directed I have installed eclipse 3.7.1 again and then installed AJDT_2.1.3_for_eclipse_3.7 by following above 4 steps.
When I restarted eclipse after installing AJDT, it is giving following error in eclipse/configuration/1328730311553.log file
!SESSION 2012-02-09 01:15:11.431 -----------------------------------------------
eclipse.buildId=M20110909-1335
java.version=1.6.0_20
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_IN
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 4 0 2012-02-09 01:15:11.960
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle org.eclipse.osgi.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.resume(InternalSystemBundle.java:225)
at org.eclipse.osgi.framework.internal.core.Framework.launch(Framework.java:655)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:273)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:175)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.NullPointerException
at java.nio.charset.CharsetEncoder.encode(CharsetEncoder.java:561)
at java.lang.StringCoding$StringEncoder.encode(StringCoding.java:258)
at java.lang.StringCoding.encode(StringCoding.java:290)
at java.lang.String.getBytes(String.java:954)
at java.io.UnixFileSystem.getLastModifiedTime(Native Method)
at java.io.File.lastModified(File.java:843)
at java.util.zip.ZipFile.<init>(ZipFile.java:131)
at java.util.zip.ZipFile.<init>(ZipFile.java:148)
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:274)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.basicOpen(ZipBundleFile.java:87)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:100)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.checkedOpen(ZipBundleFile.java:73)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.getEntry(ZipBundleFile.java:245)
at org.eclipse.equinox.weaving.hooks.WeavingBundleFile.getEntry(Unknown Source)
at org.eclipse.osgi.baseadaptor.bundlefile.BundleFileWrapperChain.getEntry(BundleFileWrapperChain.java:43)
at org.eclipse.osgi.baseadaptor.BaseData.getEntry0(BaseData.java:114)
at org.eclipse.osgi.baseadaptor.BaseData.getEntry(BaseData.java:105)
at org.eclipse.osgi.internal.baseadaptor.AdaptorUtil.loadManifestFrom(AdaptorUtil.java:187)
at org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook.getGeneratedManifest0(EclipseStorageHook.java:410)
at org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook.getGeneratedManifest(EclipseStorageHook.java:397)
at org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook.createCachedManifest(EclipseStorageHook.java:392)
at org.eclipse.core.runtime.internal.adaptor.CachedManifest.getManifest(CachedManifest.java:42)
at org.eclipse.core.runtime.internal.adaptor.CachedManifest.get(CachedManifest.java:142)
at org.eclipse.core.runtime.internal.adaptor.CachedManifest.get(CachedManifest.java:1)
at org.eclipse.osgi.framework.internal.core.ManifestLocalization.lookupResourceBundle(ManifestLocalization.java:104)
at org.eclipse.osgi.framework.internal.core.ManifestLocalization.getResourceBundle(ManifestLocalization.java:91)
at org.eclipse.osgi.framework.internal.core.ManifestLocalization.getHeaders(ManifestLocalization.java:52)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getHeaders(AbstractBundle.java:964)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getHeaders(AbstractBundle.java:911)
at org.eclipse.equinox.weaving.hooks.SupplementerRegistry.addSupplementer(Unknown Source)
at org.eclipse.equinox.weaving.hooks.WeavingHook.initialize(Unknown Source)
at org.eclipse.equinox.weaving.hooks.WeavingHook.frameworkStart(Unknown Source)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStart(BaseAdaptor.java:253)
at org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start(SystemBundleActivator.java:60)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 12 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2012-02-09 01:15:11.961
!MESSAGE Startup error
!STACK 1
java.lang.RuntimeException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle org.eclipse.osgi.
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.resume(InternalSystemBundle.java:233)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle org.eclipse.osgi.
... 10 more
... 12 more
kindly help....
Re: AJDT is not working in eclipse [message #793986 is a reply to message #793974] Wed, 08 February 2012 15:03 Go to previous messageGo to next message
I have not seen that problem before. Try starting with the -clean option from the command line.
Re: AJDT is not working in eclipse [message #793995 is a reply to message #793986] Wed, 08 February 2012 15:15 Go to previous messageGo to next message
I have not done any clean option.
But when I have again opened eclipse SDK, it is again opened normally.
And one thing has changed, initially it was showing a small red cross sign on the Aspectj project icon in Project Explorer, but it is showing it without that red mark.
Might be this is because I have installed eclipse and AJDT fresh.
But still when I am running the code, it is giving following error:
Kindly help...
Re: AJDT is not working in eclipse [message #793998 is a reply to message #793995] Wed, 08 February 2012 15:19 Go to previous messageGo to next message
Try a clean build. Project -> Clean -> Clean all projects.
Also, make sure there are no compile errors in your project or error entries in your error log.
Re: AJDT is not working in eclipse [message #794003 is a reply to message #793998] Wed, 08 February 2012 15:29 Go to previous messageGo to next message
After doing clean, it is giving same error... Sad
Re: AJDT is not working in eclipse [message #794005 is a reply to message #794003] Wed, 08 February 2012 15:31 Go to previous messageGo to next message
I am having JRE system-library [java-6-openjdk]
Is there some issue of aspectj with jdk6. should it be 5??? If yes, then what is the procedure to do so now???
Re: AJDT is not working in eclipse [message #794015 is a reply to message #794005] Wed, 08 February 2012 15:49 Go to previous messageGo to next message
No problems with Java 6.
Is "Hello" an aspect? Can you attach your project here?
Re: AJDT is not working in eclipse [message #794025 is a reply to message #794015] Wed, 08 February 2012 16:04 Go to previous messageGo to next message
Following is the link to the project:
http://www.cse.iitb.ac.in/~shwetagarg/Hello World 2.zip
Re: AJDT is not working in eclipse [message #794030 is a reply to message #794025] Wed, 08 February 2012 16:17 Go to previous messageGo to next message
You need to add the aspectj libraries to your build path. Easiest way:
Select project, right click -> AspectJ Tools -> Remove AspectJ Capability
Select project, right click -> Configure -> Convert to AspectJ project
Re: AJDT is not working in eclipse [message #794033 is a reply to message #794030] Wed, 08 February 2012 16:22 Go to previous messageGo to next message
Thanks a ton... this is working now...
so do I need to add the aspectj libraries to my build path everytime (for every project)???
Re: AJDT is not working in eclipse [message #794049 is a reply to message #794033] Wed, 08 February 2012 16:47 Go to previous message
yes.
Previous Topic:AJDT compiler results in errors
Next Topic:Circular advice precedence - how to?
Current Time: Sat May 25 09:29:50 EDT 2013
Powered by FUDForum. Page generated in 0.02571 seconds
