| How to connect two nodes that are not contained in the connection container [message #793745] |
Wed, 08 February 2012 09:05  |
Iban Ayestaran Messages: 58 Registered: September 2011 |
Member |
Hi everybody,
In my ecore model, I have some 'modes', 'tasks' and 'connections'. Modes and tasks are contained by the root, and connections are contained by modes (as seen in the attached figure). There is also a bi-directional reference between Modes and Tasks. Mutants and tasks are nodes, and connections are links.
My problem is that as tasks do not belong to modes whereas connections do so, the tool does not allow me to draw a connection between tasks. In fact, when I click the 'connection' tool in the palette and I try to click in the task to draw the line, a prohibition symbol appears, so I cannot draw it.
What I would like is to be able to draw a connection between to tasks, and that the connection should be contained by the mode the task refers to (as you see in the figure, a task can only refer to one mode).
Does anybody know how to solve my problem??
Thanks a lot in advance,
Iban
Attachment: Ecore.png
(Size: 7.20KB, Downloaded 47 times)
| Re: How to connect two nodes that are not contained in the connection container [message #795345 is a reply to message #793745] |
Fri, 10 February 2012 06:07   |
Michael Golubev Messages: 367 Registered: July 2009 |
Your use case, in particular an additional logic of determining the container for just created link, can't be handled in GMF-T without @generated NOT code.
In your generated XXXConnectionCreateCommand, you should have method similar to this (code from ReliableRouteCreateCommand from TaiPan sample):
* Default approach is to traverse ancestors of the source to find instance of container.
* Modify with appropriate logic.
* @generated
private static Aquatory deduceContainer(EObject source, EObject target) {
// Find container element for the new link.
// Climb up by containment hierarchy starting from the source
// and return the first element that is instance of the container class.
for (EObject element = source; element != null; element = element.eContainer()) {
if (element instanceof Aquatory) {
return (Aquatory) element;
return null;
I guess that in the default generated version this method actually returns null so the creation is prohibited. Just change it according to your logic, and it should be fine. If not, debug using the breakpoint in the XXXConnectionCreateCommand #canExecute to see what goes wrong.
Also you probably will find usefull to change the XXXConnectionRerouteCommand in order to maintain the container logic after reroutes.
Michael "Borlander" Golubev
at Montages Think Tank, Prague, Czech Republic
Montages AG, Zürich, Switzerland
FUDForum. Page generated in 0.01519 seconds
