Home » Archived » M2M (model-to-model transformation) » What is the best way to merge two metamodels?
What is the best way to merge two metamodels? [message #793000] Tue, 07 February 2012 11:52
Bernhard Hoisl is currently offline Bernhard Hoisl
I want to merge two different metamodels on the M2 level and want to receive a third metamodel as output. So far I found a couple of model merging/transformation alternatives (ATL, EML) but I think these need a third and pre-defined metamodel for merging. With ATL, for example, I can merge a model A (based on MM-A) and a model B (based on MM-B) to a model C (based no MM-C). But MM-C need to be defined first.
In other words, I want to merge, for instance, MM-A and MM-B according to some rules to a third MM-C. This MM-C should contain selected elements from MM-A and MM-B (as defined in the merge rules).
Is there a simple way to achieve this behaviour with any Eclipse-based tool?
-Bernhard
Previous Topic:[ATL] Roadmap
Next Topic:[ATL] inter-model reference
Current Time: Tue May 21 16:31:47 EDT 2013
Powered by FUDForum. Page generated in 0.01508 seconds
