Home » Eclipse Projects » Mylyn » Add open editors to mylyn task(Missing feature in mylyn?)
Add open editors to mylyn task [message #792953] Tue, 07 February 2012 10:50 Go to next message
paul humphrey is currently offline paul humphrey
I occasionally (ok often) find I've created a local task without activating it, then merrily opened loads of files in eclipse. Is it possible to add the opened files to a Mylyn task?
Re: Add open editors to mylyn task [message #794506 is a reply to message #792953] Thu, 09 February 2012 06:29 Go to previous message
Steffen Pingel is currently offline Steffen Pingel
that sounds similar to the suggestion that is tracked on this bug:
329944: populate context with open editors (was: create new task from open
editors)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=329944
It'd be great if you could comment and add your thoughts and requirements to
that bug.
Steffen
> Thanks
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Previous Topic:The dreaded I/O Error occurred ...
Next Topic:Jerrit Connector - the dreaded xsrfKey problem - can't connect any more
Current Time: Sun May 26 01:26:06 EDT 2013
Powered by FUDForum. Page generated in 0.01532 seconds
