Home » Modeling » Epsilon » Websites down?(Can't reach SourceForge EpsilonLabs or Eclipse Epsilon sites)
Websites down? [message #790787] Sat, 04 February 2012 16:23 Go to next message
Mark Tippetts is currently offline Mark Tippetts
Hey,
Over the last several days, when I've tried to access pages at http://www.eclipse.org/gmt/epsilon/, I get 404 Not Found errors. Likewise, when I try to go to the EpsilonLabs site at SourceForge, I get redirected to the login prompt. Are you closing up shop, or is this a temporary problem?
Concerned,
Mark Tippetts
Re: Websites down? [message #791079 is a reply to message #790787] Sun, 05 February 2012 03:27 Go to previous messageGo to next message
Antonio Garcia-Dominguez is currently offline Antonio Garcia-Dominguez
Hi Mark,
Sorry for the inconvenience. We're right now moving Epsilon to a different project inside Eclipse, so all the URLs are in flux right now. Once the move is done we should be available here:
http://www.eclipse.org/epsilon/
Antonio
Edit: fix the URL, in case someone accidentally walks into this thread later on Smile.
[Updated on: Thu, 23 February 2012 15:20]
Report message to a moderator
Re: Websites down? [message #791129 is a reply to message #790787] Sun, 05 February 2012 05:20 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
Hi Mark,
Epsilon is in the process of moving from the GMT to the EMFT project (also under Eclipse Modelling). Please CC yourself to https://bugs.eclipse.org/bugs/show_bug.cgi?id=358216 to stay up to date with any further developments on this.
Also, thanks for bringing the epsilonlabs issue to our attention. The project still exists (although I believe most of its useful content has already been moved under eclipse.org) but it seems that SF has changed the way the wiki works and now requires authentication. I'll investigate and get back to you when I know more.
Dimitris
Re: Websites down? [message #792170 is a reply to message #791129] Mon, 06 February 2012 12:42 Go to previous message
Phew! Thanks for the updates. Smile
Previous Topic:[Epsilon] Aspects
Next Topic:[EOL][ETL] Specify Target Model during runtime
Current Time: Sat May 25 15:28:15 EDT 2013
Powered by FUDForum. Page generated in 0.02600 seconds
