| feature/plugin versions [message #789596] |
Fri, 03 February 2012 01:49  |
Do I have to match plugins version with the feature that include them?
I have a feature with a particular version, say 2, but one of the
included plugins has different version number, say 4.8. Now Buckminster
perform site.p2 action is complaining that the plugin id[2.0.0,2.0.0] is
not known to Buckminster.
The Buckminster commands used here is straightforward, and the
properties file is probably very similar to the one from the examples.
Appreciate any ideas or pointers to where I should look next.
| Re: feature/plugin versions [message #789597 is a reply to message #789596] |
Fri, 03 February 2012 01:51   |
Forgot to mention that this happens in headless mode on a Windows 7
machine, and of course it works fine from the IDE :-)
| Re: feature/plugin versions [message #789778 is a reply to message #789597] |
Fri, 03 February 2012 06:47   |
Henrik Lindberg Messages: 2428 Registered: July 2009 |
yes :)
Since your feature has specified an exact version of 2.0.0 of the
particular plugin, if that is not found, it will naturally not work.
You have to use a range.
Can not really explain what would cause that to work in the IDE (i.e.
why it is not failing). Do you perhaps have a 2.0.0 version of the
plugin available somewhere in the target platform, or installed in the IDE?
- henrik
| Re: feature/plugin versions [message #790026 is a reply to message #789778] |
Fri, 03 February 2012 13:11   |
> yes :)
May be I wasn't clear on this point. The feature specifies the correct
plugin version, but the feature version itself is different from the
plugin version.
As I understand, the IDE is behaving correctly because the feature (v
2.0.0) specifies the plugin version as 4.8.0, and the plugin version
matches that.
> Regards
> - henrik
| Re: feature/plugin versions [message #790047 is a reply to message #790026] |
Fri, 03 February 2012 13:54   |
>> yes :)
> plugin version.
huh?
A feature lives a life of its own, and has its own version. Has nothing
to do with the versions of the things it includes. Which I think answers
your original question (which I did not understand at first).
>> IDE?
> matches that.
So where exactly does it break when you are running this with headless
Buckminster?
- henrik
| Re: feature/plugin versions [message #790053 is a reply to message #790047] |
Fri, 03 February 2012 14:03   |
Yup, this is my understanding as well.
>> matches that.
> Buckminster?
I'm getting the error message from Buckminster perform site.p2 action:
No component named <plugin_id>:osgi.bundle/[2.0.0,2.0.0] is known to
Buckminster
I don't have any version restriction on this particular plugin, and its
version everywhere is 4.8.0
I don't know how/where Buckminster got this 2.0.0 except from the
feature version (Note that other plugins match the feature version, and
they all have v 2.0.0 except this one).
I cannot even find any log or stacktrce that give me any additional info.
Thanks for the help
| Re: feature/plugin versions [message #791445 is a reply to message #790053] |
Sun, 05 February 2012 15:55  |
Thomas Hallgren Messages: 3165 Registered: July 2009 |
> No component named <plugin_id>:osgi.bundle/[2.0.0,2.0.0] is known to Buckminster
> I don't have any version restriction on this particular plugin, and its version everywhere is 4.8.0
Somewhere within your resolution scope, some feature or plug-in adds this restriction. Buckminster normally tells you
the path to the resolution failure at the end of the output.
- thomas
FUDForum. Page generated in 0.05480 seconds
