| UI Acceleo Launcher Project fails [message #760437] |
Fri, 02 December 2011 06:29  |
acquigio Messages: 1 Registered: December 2011 |
Junior Member |
I've followed this simple tutorial wiki.eclipse.org/Acceleo/Getting_Started to create an UI launcher...
but when I finish and I make a click on 'Acceleo Model to Text'>'generate ecore2dataspace' are created the folder 'src-gen' empty!!
On Error Log View are showed this error:
java.io.IOException: '/elt/codegeneration/ecore2dataspace/files/generate.emtl' not found
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:409)
at elt.codegeneration.ecore2dataspace.files.Generate.<init>(Generate.java:90)
at elt.codegeneration.ecore2dataspace.ui.common.GenerateAll.doGenerate(GenerateAll.java:91)
at elt.codegeneration.ecore2dataspace.ui.popupMenus.AcceleoGenerateEcore2dataspaceAction$1.run(AcceleoGenerateEcore2dataspaceAction.java:76)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
It doesn't found the file generate.emtl but in Jar plugin are there.
If I try to start the plup-in by launching a separate Eclipse application (By Maniferst.mf) everything works!!!
I've Acceleo - Text generation from models Version: 3.1.0.
Eclipse Platform Version: 3.7.0
FUDForum. Page generated in 0.01608 seconds
