Home » Eclipse Projects » Dali » New JPA Project Wizard Platform filtering possible?
New JPA Project Wizard Platform filtering possible? [message #788486] Wed, 01 February 2012 16:51 Go to next message
Kenneth Cheung is currently offline Kenneth Cheung
We have defined some JPA Platforms. Not all of them will apply to every Target Runtime.
In the JPA Facet page of the New JPA Project Wizard there is a drop-down box for JPA Platform. Is there a way to filter out the platforms that will not apply to the selected Target Runtime? Also is there a way to set the default JPA Platform in the wizard based on the Target Runtime?
Thanks!
Re: New JPA Project Wizard Platform filtering possible? [message #789343 is a reply to message #788486] Thu, 02 February 2012 17:09 Go to previous message
Neil Hauge is currently offline Neil Hauge
There is currently no way to filter platforms by target runtime. In most cases a JPA provider could operate in any number of runtimes, although I could see the use case for adopters to exercise greater control over this in certain cases. We should be able to add this type of functionality in a future release. The same goes for default platform. Currently you can only set one platform as default and there is no way to configure per platform.
Please enter an enhancement request for this functionality if you would like to see it added.
Neil
Previous Topic:Help with Porting over to Indigo
Next Topic:Sybase ASE 15: User data types mapped to java Object type
Current Time: Sun May 26 03:24:57 EDT 2013
Powered by FUDForum. Page generated in 0.01423 seconds
