Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Running JUnit 4 tests organised with inner classes
Running JUnit 4 tests organised with inner classes [message #788050] Wed, 01 February 2012 04:38 Go to next message
Joe Lemmer is currently offline Joe Lemmer
I have organised my JUnit tests using one test class for the class that I'm testing and one static inner class each for each method / behaviour that I'm testing.
public class TestMyClass {
    public static class TestMyFirstMethod {
        @Test
        public void testMthodOneDoesSomething() {
            // test code here
        @Test
        public void testMethodOneDoesSomethingElse() {
            // test code here
    public static class TestMyMethodTwo {
        @Test
        public void testMyMthodTwoDoesSomething() {
            // test code here
This works really well for me from an organisational point of view, but I'm am having trouble finding out how to run all the scripts at once. When I shift+alt+X T to run the tests, Eclipse offers me a choice of all the inner classes to run and I seem to have to pick one rather than to run all of them at once.
I really want to run them all at the same time. Is there a way I can configure this?
Many thanks
Re: Running JUnit 4 tests organised with inner classes [message #788074 is a reply to message #788050] Wed, 01 February 2012 05:16 Go to previous messageGo to next message
Heiner Westphal is currently offline Heiner Westphal
Hello Joe,
JUnit 4 comes with a runner class called Enclosed, which does what you need.
Annotate the outer class with
@RunWith(Enclosed.class)
with Enclosed =
import org.junit.experimental.runners.Enclosed;
and you should be fine.
Hope this helps,
Heiner
Am 01.02.2012 10:38, schrieb Joe Lemmer:
> that I'm testing.
> @Test
> // test code here
> @Test
> // test code here
> @Test
> // test code here
> configure this?
> Many thanks
Re: Running JUnit 4 tests organised with inner classes [message #788105 is a reply to message #788074] Wed, 01 February 2012 05:56 Go to previous message
Heiner, thanks very much for your help. That was exactly what I wanted.
Previous Topic:Eclipse Java Testing Tools - JAVA SE and JSP
Next Topic:No Profiling data captured, whatsoever.
Current Time: Wed May 22 01:01:13 EDT 2013
Powered by FUDForum. Page generated in 0.02060 seconds
