| Problem with feature patch [message #787578] |
Tue, 31 January 2012 13:48 |
Nikolay Kasyanov Messages: 30 Registered: September 2010 Location: Russia |
Member |
I'm trying to use feature patch to replace a plugin with fixed version (I need to mess with this because fix not backported to stable version, so I did it myself).
Feature I wanted to patch: org.eclipse.emf.codegen.ecore, version=2.7.0.v20110913-1156. This feature includes plugin org.eclipse.emf.codegen.ecore, version=2.7.0.v20110913-1156
I created feature patch for org.eclipse.emf.codegen.ecore feature, called it ru.agentlab.emf.codegen.ecore.patch, added modified plugin org.eclipse.emf.codegen.ecore (with version updated to 2.7.0.v20120131).
Feature patch exported & installed with no errors, but target plugin doesn't updated.
There is not so much documentation about feature patches, I used this manual as reference, but it's for 3.5.
Interestingly, feature patch works ok with target platform definitions.
Here is feature.xml of my patch:
<feature
id="ru.agentlab.emf.codegen.ecore.patch"
label="EMF Codegen Patch"
version="1.0.0.qualifier"
provider-name="AgentLab.ru">
<description url="http://www.example.com/description">
[Enter Feature Description here.]
</description>
<copyright url="http://www.example.com/copyright">
[Enter Copyright Description here.]
</copyright>
<license url="http://www.example.com/license">
[Enter License Description here.]
</license>
<requires>
<import feature="org.eclipse.emf.codegen.ecore" version="2.7.0.v20110913-1156" patch="true"/>
<import plugin="org.eclipse.core.runtime" version="3.7.0" match="compatible"/>
<import plugin="org.eclipse.core.resources" version="3.7.0" match="compatible"/>
<import plugin="org.eclipse.jdt.core" version="3.7.0" match="compatible"/>
<import plugin="org.eclipse.jdt.launching" version="3.6.0" match="compatible"/>
<import plugin="org.eclipse.emf.ecore" version="2.7.0" match="compatible"/>
<import plugin="org.eclipse.emf.codegen" version="2.6.0" match="compatible"/>
<import plugin="org.eclipse.emf.ecore.xmi" version="2.7.0" match="compatible"/>
<import plugin="org.eclipse.text" version="3.5.0" match="compatible"/>
</requires>
<plugin
id="org.eclipse.emf.codegen.ecore"
download-size="0"
install-size="0"
version="2.7.0.v20120131"
unpack="false"/>
</feature>
I'm using Eclipse 3.7.1
FUDForum. Page generated in 0.01582 seconds
