Home » Modeling » eTrice » importURI semantics
importURI semantics [message #786452] Mon, 30 January 2012 07:56 Go to next message
Klaus Birken is currently offline Klaus Birken
Hi eTrice-team,
I am using the importURI feature of eTrice, e.g.,
	import room.basic.types.java.* from "../../org.eclipse.etrice.modellib/models/JavaTypes.room"
However, the org.eclipse.etrice.modellib is part of my Eclipse workspace, but the importing project is somewhere outside the workspace (and just imported).
Unfortunately, eTrice cannot resolve the JavaTypes.room reference - is there the possibility to use a different kind of URI (e.g. platform-URI) to resolve cases like mine?
Thanks in advance, regards,
Klaus
Re: importURI semantics [message #786523 is a reply to message #786452] Mon, 30 January 2012 09:26 Go to previous messageGo to next message
Henrik Rentz-Reichert is currently offline Henrik Rentz-Reichert
Hi Klaus,
relative paths should work. Please double check!
If you you are forced to use absolute paths (e.g. because of different drive letters on a windows machine) you can use the
following form:
import room.basic.types.java from "file:/C:/path/to/modellib/org.eclipse.etrice.modellib/models/JavaTypes.room"
HTH,
Henrik
Am 30.01.2012 13:56, schrieb Klaus Birken:
> Hi eTrice-team,
> Klaus
Re: importURI semantics [message #786569 is a reply to message #786523] Mon, 30 January 2012 10:43 Go to previous messageGo to next message
Hello Henrik,
thanks for your quick reply. Relative paths work indeed, however, might not be portable to another Eclipse installation because the location of the referencing project and the workspace with the modellib will not be in the same directory structure on all machines.
But I experimented a bit and found that the following also works:
import room.basic.types.java.* from "platform:/resource/org.eclipse.etrice.modellib/models/JavaTypes.room"
This works even if the referencing project physically is stored outside the Eclipse workspace directry. Two interesting questions remain:
- Is this supposed to work? Smile
- What happens with platform-URIs when running standalone (I do not have a proper example environment yet so I cannot test this...)?
Klaus
Re: importURI semantics [message #787397 is a reply to message #786569] Tue, 31 January 2012 09:36 Go to previous messageGo to next message
Hi Klaus,
Am 30.01.2012 16:43, schrieb Klaus Birken:
> remain:
> - Is this supposed to work? :)
I've never tried. But since Xtext tries to create an EMF URI it's no complete surprise
The eTrice generator (which is a plain Java application) is not able to deal with the platform: scheme. In this context there is
no Eclipse Platform available that could help to resolve this...
> Klaus
Re: importURI semantics [message #787406 is a reply to message #787397] Tue, 31 January 2012 09:41 Go to previous message
Ed Merks is currently offline Ed Merks
In stand-alone mode, you should be able to populate
EcorePlugin.getPlatformResourceMap with mappings for the locations of
all projects. There's even EcorePlugin.handlePlatformResourceOptions
for command line option processing...
On 31/01/2012 3:36 PM, Henrik Rentz-Reichert wrote:
> Hi Klaus,
>> remain:
>> Regards,
>> Klaus
Previous Topic:eTrice nightly builds available from download site
Next Topic:no option for 'Empty eTrice Java Project'
Current Time: Tue May 28 13:08:11 EDT 2013
Powered by FUDForum. Page generated in 0.01529 seconds
