| NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786132] |
Sun, 29 January 2012 21:41  |
Geoff Capper Messages: 9 Registered: January 2012 |
Junior Member |
I'm using GF 3.1.1 which contains EclipseLink 2.3.0.
When I attempt to perform a merge I'm getting a NullPointerException at line 900 in MergeManager.registerObjectForMergeCloneIntoWorkingCopy.
The line in the source is:
Object primaryKey = descriptor.getObjectBuilder().extractPrimaryKeyFromObject(clone, unitOfWork, true);
There is no further line in the stacktrace so I assume that descriptor is null. Descriptor is set on the previous line in the sources as:
ClassDescriptor descriptor = unitOfWork.getDescriptor(clone.getClass());
Is there any way to determine what is causing this? I'm guessing I might be missing an entity class. Is that so?
Geoff
FUDForum. Page generated in 0.01740 seconds
