Home » Eclipse Projects » BIRT » Dynamic SVG Image: Item is not supported
| Dynamic SVG Image: Item is not supported [message #720979] |
Wed, 31 August 2011 11:54  |
Originally posted by: Mirko Swillus
Hej,
I'm trying to render a SVG image that is provided as a byte array within
a DataSource, target format is PDF. All the PDF says, is
"Current report item is not supported in this report format."
When I put a JPG as a byte array into the DataSources property
'row["Image"]' (see rptdesign below) everything works fine. Furthermore,
adding an embedded SVG image works, too.
I guess I have to specify the images mime type ("image/svg+xml"), image
type or file extension, but I have no glue how to do it. All I tried
concerning this failed.
Please find the interesting part of my .rptdesign below. Thanks in advance,
Mirko Swillus
<body>
<image name="name_blue" id="15">
<property name="height">3.15625in</property>
<property name="width">7.583333333333333in</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<property name="name">Image</property>
<expression name="expression"
type="javascript">dataSetRow["Image"]</expression>
<property name="dataType">javaObject</property>
</structure>
</list-property>
<structure name="toc"/>
<property name="source">expr</property>
<expression name="valueExpr">row["Image"]</expression>
</image>
</body>
| Re: Dynamic SVG Image: Item is not supported [message #721115 is a reply to message #720979] |
Wed, 31 August 2011 18:28   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Have you set the data type to blob and tried it?
I was able to read one from a file in the image onCreate script like:
importPackage(Packages.java.io);
importPackage(Packages.java.lang);
var file = new File("C:/work/workspaces/2.6.1workspaces/BIRT -
Reports/BIRT Reports/resources/spain.svg");
var ist = new FileInputStream(file);
var lengthi = file.length();
bytesa = new ByteArrayOutputStream( lengthi);
var c;
while((c=ist.read()) != -1){
bytesa.write(c);
} ist.close();
this.data = bytesa.toByteArray();
Jason
On 8/31/2011 11:54 AM, Mirko Swillus wrote:
> Hej,
> Mirko Swillus
> <body>
> <structure>
> </structure>
> </list-property>
> </image>
> </body>
Jason Weathersby
BIRT Exchange
| Re: Dynamic SVG Image: Item is not supported [message #721269 is a reply to message #721115] |
Thu, 01 September 2011 05:50   |
Jason,
Am 01.09.2011 00:28, schrieb Jason Weathersby:
thanks for your answer, but changing 'javaObject' to 'blob' makes no
difference.
But I managed to solve the problem, with the help of [0]. As I guessed
yesterday, I had to set the MIME type explicitly, since BIRT obviously
has problems to resolve the image type itself when overhanding a SVG as
a byte array (at least within my BIRT 3.7 runtime here, providing a JPG
the same way works fine).
The resulting part of my .rptdesign looks like this now:
<body>
<image name="some" id="15">
<structure>
</structure>
</list-property>
<expression name="typeExpr">"image/svg+xml"</expression>
</image>
</body>
Mind the <expression name="typeExpr">"image/svg+xml"</expression>.
Quotes are required because it has to be a valid JavaScript Expression.
Mirko Swillus
[0]
http://www.eclipse.org/birt/ref/rom/elements/Image.html#Property-typeExpr
> var c;
> bytesa.write(c);
> } ist.close();
> Jason
>> Hej,
>> advance,
>> Mirko Swillus
>> <body>
>> <structure>
>> </structure>
>> </list-property>
>> </image>
>> </body>
| Re: Dynamic SVG Image: Item is not supported [message #721387 is a reply to message #721269] |
Thu, 01 September 2011 12:01   |
Thanks for posting.
Jason
On 9/1/2011 5:50 AM, Mirko Swillus wrote:
> Jason,
> difference.
> <body>
> <structure>
> </structure>
> </list-property>
> </image>
> </body>
> Mirko Swillus
> [0]
> > var c;
> > bytesa.write(c);
> > } ist.close();
> > Jason
> >> Hej,
> within
> Furthermore,
> >> advance,
> >> Mirko Swillus
> >> <body>
> >> <structure>
> >> </structure>
> >> </list-property>
> >> </image>
> >> </body>
Jason Weathersby
BIRT Exchange
Current Time: Fri May 24 10:11:35 EDT 2013
Powered by FUDForum. Page generated in 0.02989 seconds
