| AUT could not be started, because no valid Java JRE was specified [message #778253] |
Wed, 11 January 2012 19:24  |
I try to get my integration testing done when building the project with Jenkins/Hudson.
For that I am using the maven ant task plugin to execute the testexec application.
Everything works fine, the test suite is imported to the test db and when executing the test I get the error
[exec] Wed Jan 11 23:31:59 UTC 2012 AUT: Starting AUT: AUT MyApp
[exec] !!Error occurred !!
[exec] AUT could not be started, because no valid Java JRE was specified
[exec] Wed Jan 11 23:32:05 UTC 2012 AUT Agent: connection closed
[exec] Wed Jan 11 23:32:05 UTC 2012 Exit: Code 1
I tried to setup the JAVA_HOME variable on the hudson box but without success. Though the autagent is running and fine. Also tried to specify the -vm as AUT parameter pointing to the bin folder of the java installation but no luck.
Does anybody got an idea what could be the reason and how to fix that? It's a Linux box (32-bit) running a 32bit Java 6 (Sun/Oracle).
Thanks in advance,
Lars
| Re: AUT could not be started, because no valid Java JRE was specified [message #783755 is a reply to message #778294] |
Thu, 26 January 2012 06:50   |
Ok, got the cause of the problem. It was a wrong configuration for the AUT Path and Executable.
Please put some love into those error messages...this one is really misleading the people and it seems to be used for various error handlings. Those things really don't help to fix issues.
Another thing is that you should bring back the error log view to the Jubula RCP.
That will probably help track issues a bit more effective.
Anyway, I like how UI testing is done by Jubula...but the quality of this product makes me sometimes wonder.
FUDForum. Page generated in 0.01693 seconds
