| Gemini JPA + Glassfish = ClassNotFound [message #783881] |
Thu, 26 January 2012 11:44  |
Aaron Whiteside Messages: 3 Registered: January 2012 |
Junior Member |
Using Glassfish 3.1.2-b19
Before I tried Gemini JPA I had an Activator in my Bundle that created the EMF. For that to work I had to add an import on org.eclipse.persistence.platform.server.sunas. And now that I'm using Gemini JPA I still have that import. So I am a little perplexed as to why Gemini JPA cannot find the class. If it is using the entity bundle's classloader to load the EMF.
In my persistence.xml I have the following line:
<property name="eclipselink.target-server" value="SunAS9"/>
I suspect that is the cause of the problem, but without that I suspect I won't be able to use JTA.
[#|2012-01-26T11:17:22.913-0500|INFO|glassfish3.1.2|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=55;_ThreadName=Thread-2;|ERROR: Bundle org.eclipse.gemini.jpa [276] EventDispatcher: Error during dispatch. (javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [osgi-example] failed.
Internal Exception: Exception [EclipseLink-28006] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: ClassNotFound: [org.eclipse.persistence.platform.server.sunas.SunAS9ServerPlatform] specified in [eclipselink.target-server] property.
Internal Exception: java.lang.ClassNotFoundException: org/eclipse/persistence/platform/server/sunas/SunAS9ServerPlatform)|#]
[#|2012-01-26T11:17:22.920-0500|SEVERE|glassfish3.1.2|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=55;_ThreadName=Thread-2;|javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1402)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.callPredeploy(JPAInitializer.java:98)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.initPersistenceUnits(JPAInitializer.java:306)
at org.eclipse.gemini.jpa.provider.GeminiOSGiInitializer.initializeFromBundle(GeminiOSGiInitializer.java:119)
at org.eclipse.gemini.jpa.provider.EclipseLinkOSGiProvider.assignPersistenceUnitsInBundle(EclipseLinkOSGiProvider.java:191)
at org.eclipse.gemini.jpa.PersistenceBundleExtender.tryAssigningPersistenceUnitsInBundle(PersistenceBundleExtender.java:172)
at org.eclipse.gemini.jpa.PersistenceBundleExtender.bundleChanged(PersistenceBundleExtender.java:310)
at org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerCallback(EventDispatcher.java:868)
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:789)
at org.apache.felix.framework.util.EventDispatcher.fireBundleEvent(EventDispatcher.java:514)
at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:4244)
at org.apache.felix.framework.Felix.updateBundle(Felix.java:2186)
at org.apache.felix.framework.BundleImpl.update(BundleImpl.java:962)
at org.apache.felix.fileinstall.internal.DirectoryWatcher.update(DirectoryWatcher.java:1070)
at org.apache.felix.fileinstall.internal.DirectoryWatcher.update(DirectoryWatcher.java:849)
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:445)
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:263)
Caused by: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:221)
... 17 more
Caused by: Exception [EclipseLink-28006] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.exceptions.EntityManagerSetupException.classNotFoundForProperty(EntityManagerSetupException.java:133)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.findClassForProperty(EntityManagerSetupImpl.java:842)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.updateServerPlatform(EntityManagerSetupImpl.java:639)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1159)
... 16 more
Caused by: java.lang.ClassNotFoundException: org/eclipse/persistence/platform/server/sunas/SunAS9ServerPlatform
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.getClassForName(PrivilegedAccessHelper.java:119)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.findClass(EntityManagerSetupImpl.java:832)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.findClassForProperty(EntityManagerSetupImpl.java:838)
... 18 more
If I remove the line:
From my persistence.xml I get the following exception..
[#|2012-01-26T11:37:55.586-0500|INFO|glassfish3.1.2|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=81;_ThreadName=Thread-2;|[EL Severe]: 2012-01-26 11:37:55.582--ServerSession(1197114060)--Local Exception Stack:
Exception [EclipseLink-7060] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.ValidationException
Exception Description: Cannot acquire data source [jdbc/osgi-example].
Internal Exception: javax.naming.NamingException: Lookup failed for 'jdbc/osgi-example' in SerialContext[myEnv={java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl, java.naming.factory.url.pkgs=com.sun.enterprise.naming} [Root exception is javax.naming.NamingException: Unable to lookup resource : jdbc/osgi-example [Root exception is javax.naming.CommunicationException: Communication exception for SerialContext[myEnv={java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl, java.naming.factory.url.pkgs=com.sun.enterprise.naming} [Root exception is java.lang.NullPointerException]]]
at org.eclipse.persistence.exceptions.ValidationException.cannotAcquireDataSource(ValidationException.java:497)
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIConnector.java:109)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connectInternal(DatasourceAccessor.java:330)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.connectInternal(DatabaseAccessor.java:293)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connect(DatasourceAccessor.java:418)
at org.eclipse.persistence.sessions.server.ConnectionPool.buildConnection(ConnectionPool.java:216)
at org.eclipse.persistence.sessions.server.ExternalConnectionPool.startUp(ExternalConnectionPool.java:146)
at org.eclipse.persistence.sessions.server.ServerSession.connect(ServerSession.java:484)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:633)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:208)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:488)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:294)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:272)
at com.mm.osgiexample.OSGiEntityManagerFactoryFactory.create(OSGiEntityManagerFactoryFactory.java:32)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:145)
at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:570)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:982)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:878)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:484)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:455)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:293)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:290)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:192)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137)
at java.lang.Thread.run(Thread.java:722)
Caused by: javax.naming.NamingException: Lookup failed for 'jdbc/osgi-example' in SerialContext[myEnv={java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl, java.naming.factory.url.pkgs=com.sun.enterprise.naming} [Root exception is javax.naming.NamingException: Unable to lookup resource : jdbc/osgi-example [Root exception is javax.naming.CommunicationException: Communication exception for SerialContext[myEnv={java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl, java.naming.factory.url.pkgs=com.sun.enterprise.naming} [Root exception is java.lang.NullPointerException]]]
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:518)
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:455)
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:654)
at javax.naming.InitialContext.lookup(InitialContext.java:415)
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIConnector.java:103)
... 37 more
Caused by: javax.naming.NamingException: Unable to lookup resource : jdbc/osgi-example [Root exception is javax.naming.CommunicationException: Communication exception for SerialContext[myEnv={java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl, java.naming.factory.url.pkgs=com.sun.enterprise.naming} [Root exception is java.lang.NullPointerException]]
at org.glassfish.javaee.services.ResourceProxy.throwResourceNotFoundException(ResourceProxy.java:119)
at org.glassfish.javaee.services.ResourceProxy.create(ResourceProxy.java:95)
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:507)
... 42 more
Caused by: javax.naming.CommunicationException: Communication exception for SerialContext[myEnv={java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl, java.naming.factory.url.pkgs=com.sun.enterprise.naming} [Root exception is java.lang.NullPointerException]
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:542)
at javax.naming.InitialContext.lookup(InitialContext.java:411)
at com.sun.appserv.connectors.internal.api.ResourceNamingService.lookup(ResourceNamingService.java:221)
at org.glassfish.javaee.services.ResourceProxy.create(ResourceProxy.java:93)
... 43 more
Caused by: java.lang.NullPointerException
at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1432)
at org.apache.felix.framework.B|#]
[#|2012-01-26T11:37:55.587-0500|INFO|glassfish3.1.2|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=81;_ThreadName=Thread-2;|undleWiringImpl.access$400(BundleWiringImpl.java:72)
at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.loadClass(BundleWiringImpl.java:1843)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at com.sun.naming.internal.VersionHelper12.loadClass(VersionHelper12.java:63)
at javax.naming.spi.NamingManager.getObjectFactoryFromReference(NamingManager.java:146)
at javax.naming.spi.NamingManager.getObjectInstance(NamingManager.java:319)
at com.sun.enterprise.naming.impl.SerialContext.getObjectInstance(SerialContext.java:556)
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:514)
... 48 more
[#|2012-01-26T11:37:55.593-0500|INFO|glassfish3.1.2|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=90;_ThreadName=Thread-2;|[EL Info]: 2012-01-26 11:37:55.589--ServerSession(1197114060)--EclipseLink, version: Eclipse Persistence Services - 2.3.2.v20111125-r10461
[#|2012-01-26T11:37:55.594-0500|INFO|glassfish3.1.2|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=81;_ThreadName=Thread-2;|[EL Severe]: 2012-01-26 11:37:55.594--ServerSession(1197114060)--Local Exception Stack:
... 37 more
... 42 more
... 43 more
[#|2012-01-26T11:37:55.599-0500|INFO|glassfish3.1.2|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=81;_ThreadName=Thread-2;|undleWiringImpl.access$400(BundleWiringImpl.java:72)
... 48 more
[#|2012-01-26T11:37:55.602-0500|INFO|glassfish3.1.2|org.springframework.beans.factory.support.DefaultListableBeanFactory|_ThreadID=76;_ThreadName=Thread-2;|Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@36d65080: defining beans [osgiEntityManagerFactoryFactory,entityManagerFactory,org.eclipse.gemini.blueprint.service.exporter.support.OsgiServiceFactoryBean#0]; root of factory hierarchy|#]
[#|2012-01-26T11:37:55.604-0500|INFO|glassfish3.1.2|org.eclipse.gemini.blueprint.extender.internal.activator.ContextLoaderListener|_ThreadID=76;_ThreadName=Thread-2;|Application context succesfully closed (OsgiBundleXmlApplicationContext(bundle=com.mm.osgi-example.entity, config=osgibundle:/META-INF/spring/*.xml))|#]
[#|2012-01-26T11:37:55.606-0500|INFO|glassfish3.1.2|org.springframework.beans.factory.support.DefaultListableBeanFactory|_ThreadID=76;_ThreadName=Thread-2;|Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@44a453a3: defining beans [jtaUserTransaction,jtaTransactionManager,springTransactionManager,entityManagerFactory,org.springframework.aop.config.internalAutoProxyCreator,org.springframework.transaction.annotation.AnnotationTransactionAttributeSource#0,org.springframework.transaction.interceptor.TransactionInterceptor#0,org.springframework.transaction.config.internalTransactionAdvisor,org.springframework.context.annotation.internalConfigurationAnnotationProcessor,org.springframework.context.annotation.internalAutowiredAnnotationProcessor,org.springframework.context.annotation.internalRequiredAnnotationProcessor,org.springframework.context.annotation.internalCommonAnnotationProcessor,org.springframework.context.annotation.internalPersistenceAnnotationProcessor,exampleService,org.eclipse.gemini.blueprint.service.exporter.support.OsgiServiceFactoryBean#0]; root of factory hierarchy|#]
[#|2012-01-26T11:37:55.608-0500|SEVERE|glassfish3.1.2|org.eclipse.gemini.blueprint.extender.internal.activator.ContextLoaderListener|_ThreadID=81;_ThreadName=Thread-2;|Application context refresh failed (OsgiBundleXmlApplicationContext(bundle=com.mm.osgi-example.entity, config=osgibundle:/META-INF/spring/*.xml))
java.lang.IllegalStateException: BeanFactory not initialized or already closed - call 'refresh' before accessing beans via the ApplicationContext
at org.springframework.context.support.AbstractRefreshableApplicationContext.getBeanFactory(AbstractRefreshableApplicationContext.java:171)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:337)
[#|2012-01-26T11:37:55.611-0500|SEVERE|glassfish3.1.2|org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor|_ThreadID=81;_ThreadName=Thread-2;|Unable to create application context for [com.mm.osgi-example.entity], unsatisfied dependencies: none
FUDForum. Page generated in 0.03730 seconds
