Home » Eclipse Projects » BIRT » Custom Color/Gradient Palette definition through DE API
| Custom Color/Gradient Palette definition through DE API [message #783522] |
Wed, 25 January 2012 17:00  |
jeanbaptiste.guillois Messages: 21 Registered: August 2011 |
Junior Member |
I am generating a report using the DE API (BIRT 3.7.1) but i am stuck at customizing the Palette used by my PieGraph.
The only way i have found to manage the color palette is through the following code:
SeriesDefinition segroup = SeriesDefinitionImpl.create();
segroup.getSeriesPalette().update(0);
I can only update(int) or shift(int) the Palette!
I need to specify the colors to be used in my Palette for my pieChart as well as specify through DE API some gradients for each palette entry.
Any luck that somebody might know how to do this?
Many thanks,
Best Regards,
Jean-Baptiste
| Re: Custom Color/Gradient Palette definition through DE API [message #783874 is a reply to message #783522] |
Thu, 26 January 2012 11:18  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Try:
segroup.getSeriesPalette( ).getEntries( ).clear( );
segroup.getSeriesPalette().getEntries().add( GradientImpl.create(
ColorDefinitionImpl.create(220,237,248),
ColorDefinitionImpl.create(80,166,218), 0, false));
ColorDefinitionImpl.create(255,213,213),
ColorDefinitionImpl.create(242,88,106), 0, false));
ColorDefinitionImpl.create(255,247,213),
ColorDefinitionImpl.create(232,172,57), 0, false));
ColorDefinitionImpl.create(213,255,213),
ColorDefinitionImpl.create(128,255,128), 0, false));
ColorDefinitionImpl.create(213,255,255),
ColorDefinitionImpl.create(64,128,128), 0, false));
ColorDefinitionImpl.create(226,226,241),
ColorDefinitionImpl.create(128,128,192), 0, false));
Jason
On 1/25/2012 5:00 PM, jeanbaptiste.guillois wrote:
> Hello,
> following code:
> I can only update(int) or shift(int) the Palette! I need to specify the
> Many thanks,
> Best Regards,
> Jean-Baptiste
Jason Weathersby
BIRT Exchange
Current Time: Fri May 24 06:48:05 EDT 2013
Powered by FUDForum. Page generated in 0.01558 seconds
