| Re: org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred: Invalid javascrip [message #782388 is a reply to message #781160] |
Mon, 23 January 2012 11:30  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Are you calling the stored procedures from the scripted data source?
If so do you have all the jars for the scripted data source in the
scriptlib directory(version <=2.6.2)?
Jason
On 1/20/2012 2:22 PM, Poornima Gupta wrote:
> I'm using scripted data source.
> All the data is coming from stored procedures, I cannot use jdbc
> datasource.
> Even with one simple element, any data type i get the same error.
> stack is :
> etail : org.eclipse.birt.report.engine.api.EngineException: A BIRT
> exception occurred. See next exception for more information.
> Invalid javascript expression: dataSetRow["totProdCount"] (Element ID:573)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1214)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1193)
> at
> org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
> at
> org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
> at
> org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
> 1937,2-9 22%
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.01607 seconds
