Home » Eclipse Projects » BIRT » BigDecimal columns not showing up in chart from HIVE source(HIVE as a datasource for BIRT report)
BigDecimal columns not showing up in chart from HIVE source [message #780839] Thu, 19 January 2012 10:01 Go to next message
Rod MacDonald is currently offline Rod MacDonald
I am trying to use HIVE as a datasource for a report. I was seeing the exception
described in a bug report (bugs.eclipse.org/bugs/show_bug.cgi?id=362714).
So, I upgraded to the latest stable version of the BIRT plugin (3.7.2.v20120117).
My report is now generated, however, all of the columns of type BigDecimal are blank and I don't see any errors in the logs.
Is anyone successfully using HIVE as a datasource?
Re: BigDecimal columns not showing up in chart from HIVE source [message #780890 is a reply to message #780839] Thu, 19 January 2012 14:45 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Rod,
What does the data type set to in the data set editor? Look at output
columns.
Jason
> exception
> (3.7.2.v20120117).
Jason Weathersby
BIRT Exchange
Re: BigDecimal columns not showing up in chart from HIVE source [message #780896 is a reply to message #780890] Thu, 19 January 2012 15:16 Go to previous messageGo to next message
The columns are "Decimal".
I have hadoop-hive-0.7.1+42.9-2 installed and running on my cluster.
Rod
Re: BigDecimal columns not showing up in chart from HIVE source [message #780899 is a reply to message #780896] Thu, 19 January 2012 15:56 Go to previous messageGo to next message
When you preview the dataset is it returning rows and the one column
just shows empty? Any chance you could deploy the report in a runtime
and set the log level to fine and post the log?
Jason
> Rod
Jason Weathersby
BIRT Exchange
Re: BigDecimal columns not showing up in chart from HIVE source [message #781139 is a reply to message #780899] Fri, 20 January 2012 11:52 Go to previous messageGo to next message
Sorry, the "WARNING: Method not supported" is showing up for getBigDecimal.
The org.eclipse.birt.report.data.oda.jdbc.ResultSet is being passed a
org.apache.hadoop.hive.jdbc.HiveQueryResultSet, which does not support
getBigDecimal. The "getObject" from HiveQueryResultSet returns a Long.
That appears to be the reason for my empty columns.
By adding the following to the getBigDecimal methods of org.eclipse.birt.report.data.oda.jdbc.ResultSet I am able to get results:
if (value instanceof Number) {
return new BigDecimal(((Number)value).longValue());
Rod
Re: BigDecimal columns not showing up in chart from HIVE source [message #781150 is a reply to message #781139] Fri, 20 January 2012 12:58 Go to previous messageGo to next message
Rod,
Thanks for the update. Any chance you could put that info in a bugzilla
entry?
Jason
> Rod
Jason Weathersby
BIRT Exchange
Re: BigDecimal columns not showing up in chart from HIVE source [message #781156 is a reply to message #781150] Fri, 20 January 2012 13:21 Go to previous messageGo to next message
I create a bug report (bugs.eclipse.org/bugs/show_bug.cgi?id=369267)
Re: BigDecimal columns not showing up in chart from HIVE source [message #782380 is a reply to message #781156] Mon, 23 January 2012 11:17 Go to previous message
Thanks for posting this.
Jason
Jason Weathersby
BIRT Exchange
Previous Topic:OSGI platform failing to start
Next Topic:org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred: Invalid javascript ex
Current Time: Thu May 23 19:39:25 EDT 2013
Powered by FUDForum. Page generated in 0.01717 seconds
