Home » Language IDEs » Java Development Tools (JDT) » Which Eclipse Package is compatible with Crystal 3.5 on Win 64-bit
Which Eclipse Package is compatible with Crystal 3.5 on Win 64-bit [message #781883] Sun, 22 January 2012 11:10 Go to next message
Waths B. is currently offline Waths B.
I'm trying to install Crystal 3.5 to work with Eclipse 3.7. I'm working on A WIN 7 64 bit machine. When I tried to install it gives the following error message.
Cannot complete the install because one or more required items could not be found.
Software being installed: Crystal 3.5.0 (edu.cmu.cs.crystal.feature.feature.group 3.5.0)
Missing requirement: Crystal 3.5.0 (edu.cmu.cs.crystal.feature.feature.group 3.5.0) requires 'edu.cmu.cs.planno 1.0.1' but it could not be found
I searched for this error, but could get any help. does this happen because of Eclipse 3.7? Even though in Crystal site they have mentioned that Crystal 3.5 is recommended with Eclipse 3.5, I couldn't find a Eclipse 3.5 version compatible with Win 7 64-bit o/s. Really appreciate someone tell me a solution for this.
Re: Which Eclipse Package is compatible with Crystal 3.5 on Win 64-bit [message #781908 is a reply to message #781883] Sun, 22 January 2012 12:45 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
> be found.
edu.cmu.cs.planno appears to be a plugin developed at Carnegie Mellon
University called Plaid Annotations. You would have to get this plugin
and install it before you can install the Crystal plugin.
Re: Which Eclipse Package is compatible with Crystal 3.5 on Win 64-bit [message #782043 is a reply to message #781908] Sun, 22 January 2012 21:47 Go to previous message
It worked!! Thank you very much Smile
Previous Topic:[glassfish] AppClient deployment
Next Topic:Question about showing tooltips of comment of my own method?
Current Time: Sat May 18 12:02:58 EDT 2013
Powered by FUDForum. Page generated in 0.01535 seconds
