Home » Eclipse Projects » Rich Client Platform (RCP) » Tweak classloader: RCP over not 100% reliable network (Config.ini, class loading)
Tweak classloader: RCP over not 100% reliable network (Config.ini, class loading) [message #780971] Wed, 18 January 2012 23:30
Leung Wang Hei is currently offline Leung Wang Hei
Member
I asked in platform group but not reply so far. Very appreciated if
could get any hints here.
Hi all,
Our RCP application is placed on a shared network driver, during any
network failover, there could be 1~2 seconds down time. Any file
access/class loading right at that moment just hangs the application.
So far I found 3 pitfalls:
1. loading <app>/configuration/config.ini at startup (app won't start if
missing the file/folder)
2. cache file <app>/configuration/ (could be pointed to an empty
location @user's local PC and let the files auto-generated)
3. lazy loading class from <app>/plugins
Questions:
a. Is my statement in bracket for point (2) valid? Will it potentially
break any logic?
b. Could we make RCP load config.ini out of the configuration/ folder?
c. How could I set a customized classloader (e.g. re-loading class after
1 second if fail) to bundles?
Leung Wang Hei
Previous Topic:Unable to launch RCP application via WebSphere Application Server 7
Next Topic:Tweak classloader: RCP over not 100% reliable network (Config.ini, class loading)
Current Time: Sat May 18 06:34:16 EDT 2013
Powered by FUDForum. Page generated in 0.04553 seconds
