Home » Eclipse Projects » Virgo » Working with Virgo and Hibernate
| Re: Working with Virgo and Hibernate [message #780844 is a reply to message #780842] |
Thu, 19 January 2012 10:13   |
Gabriel Afonso Messages: 23 Registered: December 2011 |
Junior Member |
Hi, thanks for the answer. this is the error message when I'm traying to install this example:
[2012-01-19 10:13:21.694] fs-watcher <DE0002E> Installation of par 'greenpages-hibernate-native' version '2.4.0.BUILD-SNAPSHOT' failed. org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.db' at version '2.4.0.BUILD-SNAPSHOT': Cannot resolve: greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.db
Resolver report:
An Import-Package could not be resolved. Caused by missing constraint in bundle <greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.db_2.4.0.BUILD-SNAPSHOT>
constraint: <Import-Package: org.hibernate.loader.collection; version="0.0.0"> constrained to bundle <org.eclipse.virgo.samples.hibernate.core> constrained bundle version range "[3.6.0.Final,3.6.0.Final]"
An Import-Package could not be resolved. Caused by missing constraint in bundle <greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.web_2.4.0.BUILD-SNAPSHOT>
An Import-Package could not be resolved. Caused by missing constraint in bundle <greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.app_2.4.0.BUILD-SNAPSHOT>
An Import-Package could not be resolved. Caused by missing constraint in bundle <greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.hibernate_2.4.0.BUILD-SNAPSHOT>
An Import-Package could not be resolved. Caused by missing constraint in bundle <greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-synthetic.context_2.4.0.BUILD-SNAPSHOT>
constraint: <Import-Package: greenpages; version="0.0.0"> constrained to bundle <greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.app> constrained bundle version range "[2.4.0.BUILD-SNAPSHOT,2.4.0.BUILD-SNAPSHOT]"
with attributes {module_scope=greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT}
An Import-Package could not be resolved. Caused by missing constraint in bundle <org.eclipse.virgo.samples.hibernate.core_3.6.0.Final>
constraint: <Import-Package: org.objectweb.asm; version="[3.1.0,4.0.0)">
The fragment could not be resolved because of a constraint conflict with a host, possibly because the host is already resolved. The affected fragment is org.eclipse.virgo.samples.hibernate.entitymanager_3.6.0.Final
Possible hosts:
org.eclipse.virgo.samples.hibernate.core_3.6.0.Final (not resolved)
Constraint conflict:
Import-Package: org.hibernate.annotations.common; version="3.6.0.Final"
Possible hosts:
Import-Package: org.hibernate.annotations.common.reflection; version="3.6.0.Final"
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:45)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:285)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:164)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:136)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:203)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeploymentFileSystemListener.java:174)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeploymentFileSystemListener.java:186)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeploymentFileSystemListener.java:87)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:245)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:166)
at org.eclipse.virgo.kernel.deployer.hot.WatchTask.run(WatchTask.java:58)
at java.lang.Thread.run(Thread.java:662)
[2012-01-19 10:13:21.698] fs-watcher <DE0003E> Install failed for bundle 'greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.db' version '2.4.0.BUILD-SNAPSHOT'.
[2012-01-19 10:13:21.703] fs-watcher <DE0003E> Install failed for bundle 'greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.app' version '2.4.0.BUILD-SNAPSHOT'.
[2012-01-19 10:13:21.705] fs-watcher <DE0003E> Install failed for bundle 'greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.web' version '2.4.0.BUILD-SNAPSHOT'.
[2012-01-19 10:13:21.707] fs-watcher <DE0003E> Install failed for bundle 'greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.hibernate' version '2.4.0.BUILD-SNAPSHOT'.
[2012-01-19 10:13:21.708] fs-watcher <DE0003E> Install failed for par 'greenpages-hibernate-native' version '2.4.0.BUILD-SNAPSHOT'.
[2012-01-19 10:13:21.711] fs-watcher <DE0500E> Unable to install application from URI 'file:/home/gafonso/Virgo/virgo-tomcat-server-3.0.2.RELEASE/pickup/greenpages-solution-hibernate-native-2.4.0.BUILD-SNAPSHOT.par'. Cannot satisfy constraints for bundle 'greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.db' version '2.4.0.BUILD-SNAPSHOT'. Cannot resolve: greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.db
Resolver report:
Possible hosts:
Possible hosts:
Resolver report:
Possible hosts:
Possible hosts:
[2012-01-19 10:13:21.727] fs-watcher <HD0002E> Hot deploy failed for file 'greenpages-solution-hibernate-native-2.4.0.BUILD-SNAPSHOT.par'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Dependency satisfaction failed
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:288)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.db' at version '2.4.0.BUILD-SNAPSHOT': Cannot resolve: greenpages-hibernate-native-2.4.0.BUILD-SNAPSHOT-greenpages.db
Resolver report:
Possible hosts:
Possible hosts:
... 10 common frames omitted
I'm using Virgo 3.0.2.Release and the springframework.3.0.5
I use the same Hibernate library showed in the example
[Updated on: Thu, 19 January 2012 10:16] Report message to a moderator
| Re: Working with Virgo and Hibernate [message #780921 is a reply to message #780905] |
Thu, 19 January 2012 17:56  |
Dmitry Sklyut Messages: 252 Registered: January 2010 |
Gabriel,
Did you populate h2 database with data?
5. Start demo database
cd virgo-samples-greenpages/db
./run.sh
./data.sh
NOTE: data.sh will preload some data and create schema.
in db/db.sql you will find:
INSERT INTO LISTING VALUES(1, 'Rod', 'Johnson', 'rod.johnson@springsource.com');
INSERT INTO LISTING VALUES(2, 'Rob', 'Harrop', 'rob.harrop@springsource.com');
INSERT INTO LISTING VALUES(3, 'Glyn', 'Normington', 'glyn.normington@springsource.com');
INSERT INTO LISTING VALUES(4, 'Andy', 'Wilkinson', 'andy.wilkinson@springsource.com');
INSERT INTO LISTING VALUES(5, 'Ben', 'Hale', 'ben.hale@springsource.com');
INSERT INTO LISTING VALUES(6, 'Chris', 'Frost', 'chris.frost@springsource.com');
INSERT INTO LISTING VALUES(7, 'Steve', 'Powell', 'steve.powell@springsource.com');
INSERT INTO LISTING VALUES(8, 'Christian', 'Dupuis', 'christian.dupuis@springsource.com');
Current Time: Sun May 19 21:19:44 EDT 2013
Powered by FUDForum. Page generated in 0.02654 seconds
