Home » Eclipse Projects » OSEE » How to export branch data in OSEE?
How to export branch data in OSEE? [message #780755] Thu, 19 January 2012 05:09
Swapna Missing name is currently offline Swapna Missing name
I would like to export the branch data in OSEE. But the export option on the branch is not there. The reason is in H2 db i had created a branch with some artifacts, now my db is changed to PostgreSQL,so I would like to import the branch that was created in H2 db. Can you please let me know how to achieve this ?
I noticed that on the server side there are commands to export and import branched, but the export branch command failed in between throwing OseeArgumentException. The incomplete data was from all branches, how can i use this command to export only for selected branches.
Previous Topic:Error: Osee_type_id_map does not exist
Next Topic:New OSee Types requires Sever restart
Current Time: Tue Jun 18 03:25:01 EDT 2013
Powered by FUDForum. Page generated in 0.01686 seconds
