Home » Modeling » M2T (model-to-text transformation) » [Acceleo] - Help with a small exercise.
[Acceleo] - Help with a small exercise. [message #780452] Tue, 17 January 2012 19:39 Go to next message
John  Doe is currently offline John Doe
edited.
Thank you.
[Updated on: Sat, 21 January 2012 07:59]
Report message to a moderator
Re: [Acceleo] - Help with a small exercise. [message #780505 is a reply to message #780452] Wed, 18 January 2012 06:03 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
It would indeed be something easy for one of us... but the point of your exercise is not to have someone do your homework for you. Rather to make you discover a new tool... and teach you how to learn by yourself as you will most likely have to do in your professional life Smile.
As for how to create the generator, please try and follow the Getting Started guide and try to at least get a first basic draft of what you need. We will help if you hit a wall Smile.
Laurent Goubet
Obeo
Re: [Acceleo] - Help with a small exercise. [message #780511 is a reply to message #780505] Wed, 18 January 2012 06:43 Go to previous messageGo to next message
Laurent Goubet wrote on Wed, 18 January 2012 06:03
Laurent Goubet
Obeo
Thank you Laurent, I really appreciate your help! Smile
I'll try to make a basic generator with the basic structure I have in mind and I'll post it in the evening. Again, thank you for your support!
Re: [Acceleo] - Help with a small exercise. [message #780641 is a reply to message #780452] Wed, 18 January 2012 15:52 Go to previous message
Dave Donald is currently offline Dave Donald
this is a common problem seen in many excercises, unfortunantly I have never seen someone posting a solution to this commond problem.
have you founded some solution to the problem?
I have a working environment, I have generated a mtl that can print all class names and all methods of the classes.
But how can I see what class extends what class, aggregation, inference, if a class is abstract ecc ecc. ?
[Updated on: Sat, 21 January 2012 08:05]
Previous Topic:[Acceleo] What UML2 modeling tool provides a complete integration with Acceleo?
Next Topic:Print all class names.
Current Time: Tue May 21 17:34:30 EDT 2013
Powered by FUDForum. Page generated in 0.08415 seconds
