Home » Eclipse Projects » Plugin Development Environment (PDE) » QuickFix (Marker Resolutions) not available in the Editor, only in Problems-View?(Marker-Resolutions from the extension point "org.eclipse.ui.ide.markerResolution" only show up in the "Problems"-View, not on the editors Annotations.)
QuickFix (Marker Resolutions) not available in the Editor, only in Problems-View? [message #779487] Sun, 15 January 2012 16:51 Go to next message
Janos Kutscherauer is currently offline Janos Kutscherauer
Hello guys,
i am trying to define custom problem markers and custom Quick-Fixes for some specific eclipse editors. In particular, i'm trying with the default Text Editor (org.eclipse.ui.DefaultTextEditor) and the quasi-standard XML Editor (org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditorPart).
I must be missing out something, but i only see my defined marker resolutions (Quick-Fixes) in the "Problems"-View (by the markers context-menu, or by the shortcut Strg+1 on some marker). However i actually expect the marker resolutions to also appear in the editor itself: When pressing Strg+1 on the marked line/characters, or on the left-hand-sided annotation bar. Just like for instance the Java editor, or also the XML editor provides the Quick-Fixes.
My extension looks like this:
<extension point="org.eclipse.ui.ide.markerResolution">
   <markerResolutionGenerator
         class="com.validator.test.MarkerResolutionGenerator"
         markerType="org.eclipse.core.resources.problemmarker">
   </markerResolutionGenerator>
</extension>
The resolution works for the basic problem markers "org.eclipse.core.resources.problemmarker", but as mentioned only in the Problems View.
What am i missing? Is there a entirely different concept/extension point responsible for providing Quick-Fixes in the editor?
I'd be glad to read your comments - thank you!
Re: QuickFix (Marker Resolutions) not available in the Editor, only in Problems-View? [message #781965 is a reply to message #779487] Sun, 22 January 2012 16:28 Go to previous messageGo to next message
Kitesurfer () is currently offline Kitesurfer ()
Member
I don't have the problem you describe. When I add markers via below code they appear both on the problems-view and in the editor (lcIFile is an IFile of a particular editor).
IMarker lcMarker = lcIFile.createMarker(IMarker.PROBLEM);
lcMarker.setAttribute(IMarker.LINE_NUMBER, lcErrorLineNumber );
lcMarker.setAttribute(IMarker.CHAR_START, lcOffSet );
lcMarker.setAttribute(IMarker.CHAR_END, lcOffSet + lcWordLen );
lcMarker.setAttribute(IMarker.MESSAGE, lcErrorText);
lcMarker.setAttribute(IMarker.TEXT, lcErrorText);
lcMarker.setAttribute(IMarker.PRIORITY, IMarker.PRIORITY_HIGH);
if (warning == true) {
lcMarker.setAttribute(IMarker.SEVERITY , IMarker.SEVERITY_WARNING);
} else {
lcMarker.setAttribute(IMarker.SEVERITY , IMarker.SEVERITY_ERROR);
Re: QuickFix (Marker Resolutions) not available in the Editor, only in Problems-View? [message #782845 is a reply to message #779487] Tue, 24 January 2012 10:05 Go to previous message
Hello and thank you for your answer.
However i have no problems with Markers either, but with their Resolutions, a.k.a. "QuickFixes". They don't appear in the editors Resolution lists, only in the Problems View's list.
Previous Topic:How to obtain a progress monitor w/o a Job?
Next Topic:Export Deployable Features - Java Web Start Tab
Current Time: Sun May 26 01:26:54 EDT 2013
Powered by FUDForum. Page generated in 0.01651 seconds
