So, exactly WHERE do I find the Delta packs?
I have a WIn32 app working, and I'd like to make a Linux build.
Also, it seems that you need to have a Delta pack version that exactly matches your Eclipse version.
I have yet to find a place in Eclipse that shows the exact version number. Just things like Indigo and Build Id.
Paul Webster Messages: 6813 Registered: July 2009 Location: Ottawa
If you look in Help>about>Installation Details there should be an entry that says Eclipse SDK (for most cases). That will have a version number like 3.6.1 or 3.7 (Indigo), and from that you can find a page with the Delta pack.
Thanks, found the version as 3.7.1.
I find it pretty weird that you have to dig around to find the Version number. Seems like you would want that in the About Box - just like every other product in the world.
I had previously gone to Eclipse.org and searched for "delta pack download", which found a zillion irrelevant things.
Adding the Eclipse version number narrowed it down, and the page I needed was at the top of the list.
