Home » Eclipse Projects » BIRT » Is it possible to Link OCL Queries to report on an EMF model?
Is it possible to Link OCL Queries to report on an EMF model? [message #771209] Mon, 26 December 2011 12:00 Go to next message
Nigel Daniels is currently offline Nigel Daniels
Member
I am new to using BIRT and I am trying to report on an EMF model. I have
set up an ODA connection to my EMF file and can report on parts of it.
What I would like to do is create a report that looks a bit like the EMF
tree view of my information. The model structure is :
A Project --- contains ---> Objectives --- contain ---> Issues
All of these elements have the string attributes, id, name and description.
I can create OCL queries based on the Project context :
self.objectives
to see all of the Objectives, then :
self.objectives.issues
to view all of the Issues, or even :
self.objectives->select(id='O1').issues
to see the Issues belonging to the Objective with the id 'O1'. Is there
anyway to nest a series of OCL quieries so that I could see each of the
objectives then their associated issues in one report.
Unlike a relational database the relationship is a feature of the file
structure in the EMF file rather than using index relationships. Because
of this I have not found a way of making join querys work as there is no
field to join on.
Any advice from a BIRT OCL expert would be very welcome!
Thanks for any help.
Regards, Nigel.
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #771252 is a reply to message #771209] Mon, 26 December 2011 14:28 Go to previous messageGo to next message
Eclipse User
Nigel,
See inline comments...
On 12/26/2011 11:02 AM, Nigel Daniels wrote:
Are you using the newest org.eclipse.emf.oda.ecore driver?
> self.objectives
> field to join on.
Right the brute force approach is to create three datasets:
Projects, Objectives, and Issues; then create a fourth Joint DataSet to
join Projects and Objectives and a fifth to join the Issues to the Joint
Projects and Objects BUT... as you say there is no index just a
containment. Plus (even if it would work) this is ugly.
But remember all EObjects do have an
public EObject eContainer()
method.
So you might try...
Creating a single dataset on all the Issues. Then add 6 computed
columns; 3 for Objective id, name and description; and 3 for Project id,
In the computed columns of your Dataset use a function like
@self.getObject().eContainer() to move upward in the hierarchy to get
the Objective then in a similar fashion
@self.getObject().eContainer().eContainer() to get the Project. Once you
are at the object you can get the values for id, name and description.
Your dataset can be now used in a BIRT table where you can group on the
Project and sub group on Objective. This last subgroup will include the
Issues in the details row.
Your Tree.
If there are any BIRT OCL experts out there that can think of a better
way, please let us know...
John
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #772318 is a reply to message #771252] Thu, 29 December 2011 09:04 Go to previous messageGo to next message
Member
Hi John,
thanks for getting back to me so quickly :) I have given these ideas a
go an I can get the container object as you suggested, so I'm a good
part of the way there but I'm not sure I know how to use OCL correctly
to get an objects id. Is there a way to cast the result then call its
methods?
I've added some comments on what i tried and the results below:
On 26/12/2011 19:28, John E. Conlon wrote:
> Nigel,
>> description.
>> self.objectives
>> field to join on.
I agree that this approach would be a bit ugly and may not scale well,
even if the EMF structure allowed for it.
> method.
Ah-ha! I did not ralise I could access this.
> So you might try...
So I gave getting hold of an Objectives Id attribute via an Issue
dataset query. The query uses the Project as the context and returns an
Issue type, the query is:
I then added a computed column called ObjectiveObj :
row["@self"].getObject().eContainer()
This gives me the following sorts of results :
Description: Test issue 1
ObjectiveObj: org.eclipse.emf.ecore.impl.DynamicEObjectImpl@59ae5a16
(eClass: org.eclipse.emf.ecore.impl.EClassImpl@38bf7b8 (name: Objective)
(instanceClassName: null) (abstract: false, interface: false))
It looks like I have the object reference to the containing Objective
object, but I'm not sure how I then cast this to an instance of
Objective to access it's getId() method?
> Your Tree.
> John
Thanks for your help,
Nigel
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #773178 is a reply to message #772318] Sat, 31 December 2011 14:27 Go to previous messageGo to next message
Eclipse User
HI Nigel,
On 12/29/2011 08:04 AM, Nigel Daniels wrote:
> Hi John,
> methods?
Don't have to cast, its JavaScript! Just go ahead and use whatever
method in the Interface for container object that allows you to get the id.
Guess - is it
getID()
>> Nigel,
>>> Hi,
>>> description.
>>> self.objectives
>>> field to join on.
>> method.
Yes, any method on your object instance should work.
>> So you might try...
Looks good
Rather call it ObjectID
and
row["@self"].getObject().eContainer().getID();
(The data type for the computed column would be a string, unless that is
of course you have a number type for the ID in your EMF model.
Again no cast needed - Just go for it and call a method.
cheers,
John
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #774616 is a reply to message #773178] Wed, 04 January 2012 04:40 Go to previous messageGo to next message
Member
Hi John,
I have tried multiple ways of calling the method I'd like to call but I
don't think I'm getting back the object I expected. When I try to call
the method using:
row["@self"].getObject().eContainer().getId();
I get the result:
org.eclipse.birt.data.engine.core.DataException: Fail to compute value
for computed column "ObjectiveObj".
A BIRT exception occurred. See next exception for more information.
There are errors evaluating script
"row["@self"].getObject().eContainer().getId();":
TypeError: Cannot find function getId in object
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@b500f60 (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@474715d4 (name: Objective)
(instanceClassName: null) (abstract: false, interface: false)).
org.eclipse.birt.data.engine.impl.ComputedColumnHelper$ComputedColumnHelperInstance.process(ComputedColumnHelper.java:523)
I also tried the variations (a bit of a guess):
row["@self"].getObject().eContainer().row["Id"];
and:
row["@self"].getObject().eContainer().column["Id"];
with the result:
"row["@self"].getObject().eContainer().row["Id"];":
TypeError: Cannot read property "Id" from undefined
Finally I tried (based on looking at the avaliable items in a dataset):
row["@self"].getObject().eContainer().Id;
This returns the data set but the computed column is empty.
I suspect my last three attempts are in error but I thought I should try
out any ideas and see if they worked out.
The result from the first attempt seems to suggest that I am not getting
back the expected object but that I have a DynamicEObjectImpl instead.
When I look at the result for running:
row["@self"].getObject().eContainer();
It gives me a result like this for the computed column:
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@51b5449f (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@6433aa85 (name: Objective)
In the attribute (name: Objective) I can see that it looks to contain
the Objective type I expect, but without the ability to type cast this
to an Objective class I suspect I will not be able to access the getId()
method. Do you have an example of how I should be doing this? It would
be great to take a look in case there is a step I have failed to do in
configuring my BIRT/EMF/ODA set-up?
Nigel
On 31/12/2011 19:27, John E. Conlon wrote:
> HI Nigel,
>> Hi John,
>> methods?
> Guess - is it
> getID()
>>> Nigel,
>>>> Hi,
>>>> have
>>>> EMF
>>>> description.
>>>> self.objectives
>>>> Because
>>>> is no
>>>> field to join on.
>>> method.
>>> So you might try...
> Looks good
> and
> cheers,
> John
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #774650 is a reply to message #774616] Wed, 04 January 2012 05:45 Go to previous messageGo to next message
Member
Hi John,
I just managed to answer my own query, as I have the DynamicEObjectImpl
wrapper I was able to use EMF techniques to access the attribute I
needed. so the computed column expression becomes:
row["@self"].getObject().eContainer().dynamicGet(1);
This returns the value of the Id attribute that I need.
Thanks for all of your help in guiding me towards this result.
Nigel
On 04/01/2012 09:42, Nigel Daniels wrote:
> Hi John,
> the method using:
> I get the result:
> at
> and:
> with the result:
> at
> Nigel
>> HI Nigel,
>>> Hi John,
>>> methods?
>> the id.
>> Guess - is it
>> getID()
>>>> Nigel,
>>>>> Hi,
>>>>> have
>>>>> EMF
>>>>> description.
>>>>> self.objectives
>>>>> there
>>>>> the
>>>>> Because
>>>>> is no
>>>>> field to join on.
>>>> Joint
>>>> method.
>>>> So you might try...
>>>> id,
>> Looks good
>>>> you
>> and
>> cheers,
>> John
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #775247 is a reply to message #774650] Thu, 05 January 2012 11:23 Go to previous messageGo to next message
Eclipse User
Hi Nigel,
First of all, I am glad you got this working, but your model behaves
different than mine.
To quote a famous wise man:
>Why question magical incantations that are working well?
Ok so I am curios...
In my case, I have a model element called Animal which contains multiple
Tag elements which contains multiple Event elements.
I can traverse upward my tree from the Event context like this:
row["@self"].getObject().getTag().getAnimal().getWeight()
But to test what we were discussing today I changed it and so can also do:
row["@self"].getObject().eContainer().eContainer().getWeight()
to get the same results.
So it seems that I am working directly with my generated EObjects while
you are not. Why?
Could you be in the same situation as:
http://www.eclipsezone.com/eclipse/forums/t107335.html
John
On 01/04/2012 04:47 AM, Nigel Daniels wrote:
> Hi John,
> Best regards,
> Nigel
>> Hi John,
>> the method using:
>> I get the result:
>> at
>> and:
>> with the result:
>> at
>> Regards,
>> Nigel
>>> HI Nigel,
>>>> Hi John,
>>>> methods?
>>> the id.
>>> Guess - is it
>>> getID()
>>>>> Nigel,
>>>>>> Hi,
>>>>>> have
>>>>>> it.
>>>>>> EMF
>>>>>> description.
>>>>>> self.objectives
>>>>>> there
>>>>>> the
>>>>>> file
>>>>>> Because
>>>>>> is no
>>>>>> field to join on.
>>>>> DataSet to
>>>>> Joint
>>>>> method.
>>>>> So you might try...
>>>>> id,
>>> Looks good
>>>>> you
>>> and
>>>>> the
>>>>> the
>>>> Objective)
>>> cheers,
>>> John
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #775760 is a reply to message #775247] Fri, 06 January 2012 11:33 Go to previous messageGo to next message
Member
Hi John,
that is odd! I wonder if it is another symptom of an early problem I
had. Whenever I tried to create a data source using my xmi file it
failed claiming it could not load a referenced namespace (my own, as I
recall). I resolved this problem by adding:
saveOptions.put(XMLResource.OPTION_SCHEMA_LOCATION, Boolean.TRUE);
To the edit code that persists the file. From then on I was able to
create the DataSource. Following the post you cited I replaced this with:
editingDomain.getResourceSet().getPackageRegistry().put("http://uk.co.acme.datagathering/1.0",
DataGatheringPackage.eINSTANCE);
I was able to create a DataSource but it still get a DynamicEObjectImpl
instead of an instance of the resource I was expecting.
I too am curious as to why this is? It would be a lot simpler to call
the methods I would expect to see. Still the incantation is working for
now ;)
Nigel
On 05/01/2012 16:23, John E. Conlon wrote:
> Hi Nigel,
> you are not. Why?
> John
>> Hi John,
>> Best regards,
>> Nigel
>>> Hi John,
>>> the method using:
>>> I get the result:
>>> at
>>> and:
>>> with the result:
>>> at
>>> Regards,
>>> Nigel
>>>> HI Nigel,
>>>>> Hi John,
>>>>> methods?
>>>> the id.
>>>> Guess - is it
>>>> getID()
>>>>>> Nigel,
>>>>>>> Hi,
>>>>>>> have
>>>>>>> it.
>>>>>>> EMF
>>>>>>> description.
>>>>>>> self.objectives
>>>>>>> there
>>>>>>> the
>>>>>>> file
>>>>>>> Because
>>>>>>> is no
>>>>>>> field to join on.
>>>>>> DataSet to
>>>>>> Joint
>>>>>> method.
>>>>>> So you might try...
>>>>>> id,
>>>>> returns an
>>>> Looks good
>>>>>> you
>>>>>> description.
>>>> and
>>>> that is
>>>>>> the
>>>>>> the
>>>>> Objective)
>>>> cheers,
>>>> John
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #775778 is a reply to message #775760] Fri, 06 January 2012 11:55 Go to previous messageGo to next message
Eclipse User
Hi Nigel,
Yep, something does not appear right with your model plugins. You
should try and fix it.
Also from a community educational standpoint...
would you mind re-posting these EMF related questions to the EMF
eclipse.tools.emf newsgroup and then if you find out a solution let us
know back on this thread?
thanks,
John
On 01/06/2012 10:33 AM, Nigel Daniels wrote:
> Hi John,
> now ;)
> Nigel
>> Hi Nigel,
>> do:
>> you are not. Why?
>> John
>>> Hi John,
>>> Best regards,
>>> Nigel
>>>> Hi John,
>>>> the method using:
>>>> I get the result:
>>>> at
>>>> and:
>>>> with the result:
>>>> at
>>>> try
>>>> getting
>>>> getId()
>>>> Regards,
>>>> Nigel
>>>>> HI Nigel,
>>>>>> Hi John,
>>>>>> ideas a
>>>>>> correctly
>>>>>> methods?
>>>>> the id.
>>>>> Guess - is it
>>>>> getID()
>>>>>>> Nigel,
>>>>>>>> Hi,
>>>>>>>> have
>>>>>>>> it.
>>>>>>>> the
>>>>>>>> EMF
>>>>>>>> description.
>>>>>>>> self.objectives
>>>>>>>> there
>>>>>>>> the
>>>>>>>> file
>>>>>>>> Because
>>>>>>>> is no
>>>>>>>> field to join on.
>>>>>>> DataSet to
>>>>>>> Joint
>>>>>> well,
>>>>>>> method.
>>>>>>> So you might try...
>>>>>>> id,
>>>>>> returns an
>>>>> Looks good
>>>>>>> get
>>>>>>> you
>>>>>>> description.
>>>>> and
>>>>> that is
>>>>>>> the
>>>>>>> the
>>>>>> Objective)
>>>>> cheers,
>>>>> John
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #776823 is a reply to message #775778] Mon, 09 January 2012 05:15 Go to previous messageGo to next message
Member
Hi John,
I've posted a question in the EMF forum so lets see if anyone can
resolve this oddity.
BTW I have also started thinking of using sub-reports to achieve the
same effect as i was looking for here. However this approach has run
into it's own problems. I'll start a new post for that issue.
Thanks for your help.
Nigel
On 06/01/2012 16:55, John E. Conlon wrote:
> Hi Nigel,
> Yep, something does not appear right with your model plugins. You should
> try and fix it.
> thanks,
> John
>> Hi John,
>> now ;)
>> Nigel
>>> Hi Nigel,
>>> do:
>>> you are not. Why?
>>> John
>>>> Hi John,
>>>> Best regards,
>>>> Nigel
>>>>> Hi John,
>>>>> but I
>>>>> the method using:
>>>>> I get the result:
>>>>> at
>>>>> and:
>>>>> with the result:
>>>>> at
>>>>> dataset):
>>>>> try
>>>>> getting
>>>>> getId()
>>>>> Regards,
>>>>> Nigel
>>>>>> HI Nigel,
>>>>>>> Hi John,
>>>>>>> ideas a
>>>>>>> correctly
>>>>>>> its
>>>>>>> methods?
>>>>>> the id.
>>>>>> Guess - is it
>>>>>> getID()
>>>>>>>> Nigel,
>>>>>>>>> Hi,
>>>>>>>>> model. I
>>>>>>>>> have
>>>>>>>>> it.
>>>>>>>>> the
>>>>>>>>> EMF
>>>>>>>>> description.
>>>>>>>>> self.objectives
>>>>>>>>> there
>>>>>>>>> each of
>>>>>>>>> the
>>>>>>>>> file
>>>>>>>>> Because
>>>>>>>>> is no
>>>>>>>>> field to join on.
>>>>>>>> DataSet to
>>>>>>>> Joint
>>>>>>> well,
>>>>>>>> method.
>>>>>>>> So you might try...
>>>>>>>> Project
>>>>>>>> id,
>>>>>>> returns an
>>>>>> Looks good
>>>>>>>> get
>>>>>>>> Once
>>>>>>>> you
>>>>>>>> description.
>>>>>> and
>>>>>> that is
>>>>>>>> the
>>>>>>>> the
>>>>>>> Objective)
>>>>>>> Objective
>>>>>> cheers,
>>>>>> John
Re: Is it possible to Link OCL Queries to report on an EMF model? [message #778758 is a reply to message #776823] Fri, 13 January 2012 14:26 Go to previous message
Eclipse User
Hi Nigel,
Saw your post in the EMF group. Ed said that the DynamicEObjectImpl was
the result of your models not being found, and asked if you have
included all your generated plugins in your app that is using BIRT.
If so have included them, you may want to insure that these plugins are
active and have met all their dependencies in order to be so. In the
OSGi console. Go to Console open up a OSGi Console, and type in ss
<your plugins symbolic name> and check out the state.
John
On 01/09/2012 04:15 AM, Nigel Daniels wrote:
> Hi John,
> Best regards,
> Nigel
>> Hi Nigel,
>> try and fix it.
>> thanks,
>> John
>>> Hi John,
>>> with:
>>> now ;)
>>> Nigel
>>>> Hi Nigel,
>>>> multiple
>>>> do:
>>>> you are not. Why?
>>>> John
>>>>> Hi John,
>>>>> DynamicEObjectImpl
>>>>> Best regards,
>>>>> Nigel
>>>>>> Hi John,
>>>>>> but I
>>>>>> call
>>>>>> the method using:
>>>>>> I get the result:
>>>>>> value
>>>>>> at
>>>>>> and:
>>>>>> with the result:
>>>>>> value
>>>>>> at
>>>>>> dataset):
>>>>>> try
>>>>>> getting
>>>>>> instead.
>>>>>> this
>>>>>> getId()
>>>>>> would
>>>>>> do in
>>>>>> Regards,
>>>>>> Nigel
>>>>>>> HI Nigel,
>>>>>>>> Hi John,
>>>>>>>> ideas a
>>>>>>>> good
>>>>>>>> correctly
>>>>>>>> its
>>>>>>>> methods?
>>>>>>> the id.
>>>>>>> Guess - is it
>>>>>>> getID()
>>>>>>>>> Nigel,
>>>>>>>>>> Hi,
>>>>>>>>>> model. I
>>>>>>>>>> have
>>>>>>>>>> parts of
>>>>>>>>>> it.
>>>>>>>>>> the
>>>>>>>>>> EMF
>>>>>>>>>> description.
>>>>>>>>>> self.objectives
>>>>>>>>>> there
>>>>>>>>>> each of
>>>>>>>>>> the
>>>>>>>>>> file
>>>>>>>>>> Because
>>>>>>>>>> there
>>>>>>>>>> is no
>>>>>>>>>> field to join on.
>>>>>>>>> DataSet to
>>>>>>>>> Joint
>>>>>>>> well,
>>>>>>>>> method.
>>>>>>>>> So you might try...
>>>>>>>>> Project
>>>>>>>>> id,
>>>>>>>> returns an
>>>>>>> Looks good
>>>>>>>>> get
>>>>>>>>> Once
>>>>>>>>> you
>>>>>>>>> description.
>>>>>>> and
>>>>>>> that is
>>>>>>>>> group on
>>>>>>>>> the
>>>>>>>>> include
>>>>>>>>> the
>>>>>>>> ObjectiveObj:
>>>>>>>> Objective)
>>>>>>>> Objective
>>>>>>> cheers,
>>>>>>> John
Previous Topic:Parameter in sequence
Next Topic:CSV export in BIRT 2.1.1 performs unwanted data formatting
Current Time: Mon May 20 01:20:39 EDT 2013
Powered by FUDForum. Page generated in 0.07370 seconds
