| Query field created by the @OrderColumn [message #778313] |
Thu, 12 January 2012 05:26  |
Alessandro Pacifici Messages: 2 Registered: January 2012 |
Junior Member |
I have an entity like this:
public class A {
@OneToMany
@OrderColumn(name = "MYORDER")
private List<B> bList;
I need to fetch from database some B objects ordered by the created MYORDER column.
If I define a field in B like this:
public class B {
@Column(name = "MYORDER")
private Integer order;
And I try to query with:
SELECT b FROM B b WHERE ... ORDER BY b.order
EclipseLink try to create the "MYORDER" column 2 times throwing an exception and doesn't create the B table.
I can't fetch A objects because I need to fetch some B objects belonging to different A objects (even no A objects)
How can I solve this?
Alessandro
[Updated on: Thu, 12 January 2012 05:37] Report message to a moderator
| Re: Query field created by the @OrderColumn [message #778623 is a reply to message #778313] |
Fri, 13 January 2012 09:43  |
Chris Delahunt Messages: 862 Registered: July 2009 |
If you just want the list to be returned ordered, use the @OrderBy annotation instead. OrderColumn causes the field to be controlled by the collection.
Please file a bug though, as the field should not be written twice. Instead, you should get an exception stating that the field is mapped twice (since both the collection and the basic mapping try to write to the field).
Best Regards,
Chris
FUDForum. Page generated in 0.01502 seconds
