Home » Eclipse Projects » WindowBuilder » DataBinding - Enumerations
DataBinding - Enumerations [message #773776] Mon, 02 January 2012 09:05 Go to next message
Thomas
happy new year to everyone!
I'm trying to bind a list of elements of type java enumeration to a combo viewer. Unfortunately I can not choose the enum type as the element bean class in the data binding dialog.
If I instead select another (dummy bean) class and manually change the code for using the enum instead everything works fine (including the fact that the enum type now gets listed in the element bean class combo box).
Can anybody please explain how to bind a list of enums to a combo viewer using WindowBuider?
Thanks in advance!
Thomas
Re: DataBinding - Enumerations [message #775765 is a reply to message #773776] Fri, 06 January 2012 11:39 Go to previous messageGo to next message
CharlieKelly  is currently offline CharlieKelly
Hi Thomas,
Have you determined how to use window builder for enumerations?
I asked a similar question the following day.
Charlie
On 1/2/2012 9:05 AM, Thomas wrote:
> box).
> using WindowBuider?
> Thanks in advance!
> Thomas
Re: DataBinding - Enumerations [message #776764 is a reply to message #775765] Mon, 09 January 2012 03:34 Go to previous messageGo to next message
Thomas
Hi Charlie,
unfortunately I haven't any news on this.
Thomas
[Updated on: Mon, 09 January 2012 03:35]
Report message to a moderator
Re: DataBinding - Enumerations [message #777393 is a reply to message #776764] Tue, 10 January 2012 07:00 Go to previous messageGo to next message
Andrey Sablin is currently offline Andrey Sablin
WB do not supports enumerations for databindings.
Re: DataBinding - Enumerations [message #778356 is a reply to message #773776] Thu, 12 January 2012 10:03 Go to previous message
Thomas
I have created an enhancement request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=368453
Previous Topic:JFace close
Next Topic:Databinding with Forms ?
Current Time: Sat May 25 19:25:51 EDT 2013
Powered by FUDForum. Page generated in 0.02240 seconds
