Home » Eclipse Projects » Vex » Error installing VEX from Eclipse Marketplace(connectors not available)
Error installing VEX from Eclipse Marketplace [message #775646] Fri, 06 January 2012 07:54 Go to next message
Manuel Sales is currently offline Manuel Sales
I'm trying to install VEX using Marketplace but I get this error..
The following connectors are not available: Vex (id=org.eclipse.wst.xml.vex.feature.feature.group, org.eclipse.wst.xml.vex_sdk.feature.feature.group, site=XXXX://download.eclipse.org/vex/milestones/)
In the error log appears the following:
eclipse.buildId=I20100608-0911
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=es_ES
Framework arguments: -product org.eclipse.epp.package.php.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.php.product
This is a continuation of log file /home/manolo/eclipseWS/.metadata/.bak_0.log
Created Time: 2012-01-06 12:32:48.492
Error
Fri Jan 06 12:32:48 CET 2012
I don't know if this is the right place to ask help for this problem, but if I'm wrong I suppose you will be able to redirect me.
Thanks in advance for your support
Re: Error installing VEX from Eclipse Marketplace [message #775823 is a reply to message #775646] Fri, 06 January 2012 13:26 Go to previous messageGo to next message
Holger Voormann is currently offline Holger Voormann
Hi Manuel,
Thank you for reporting this error.
I forgot to update the marketplace settings (the feature ID changed by the move of Vex from WTP Incubator to its own project). This is now fixed. Please retry.
Holger
Re: Error installing VEX from Eclipse Marketplace [message #777591 is a reply to message #775823] Tue, 10 January 2012 14:22 Go to previous message
Thanks a lot, now the installation works fine.
Previous Topic:Problems with new version 1.0.0 M8
Next Topic:Support for XML includes
Current Time: Wed May 22 22:39:29 EDT 2013
Powered by FUDForum. Page generated in 0.08500 seconds
