Home » Eclipse Projects » WindowBuilder » JFace(How to create a JFace window)
JFace [message #775278] Thu, 05 January 2012 12:54 Go to next message
Bill Brandley is currently offline Bill Brandley
I am playing around with WindowBuilder.
I created simple programs using "WindowBuilder/Swing Designer/Application Window" and "WindowBuilder/SWT Designer/SWT/Application Window" classes with no problem.
However, when I tryed to create a "WindowBuilder/SWT Designer/JFace/ApplicationWindow", the source code gave me unresolved imports associated with "org.eclipse.jface...".
What do I need to do to create a JFace based class without all th import errors?
Thanx,
Bill
Re: JFace [message #775292 is a reply to message #775278] Thu, 05 January 2012 13:28 Go to previous messageGo to next message
Konstantin Scheglov is currently offline Konstantin Scheglov
1. Add JFace biraries from "plugins" folder of your Eclipse, into your project classpath.
2. Just create PDE project and add dependency on org.eclipse.ui plugin.
Konstantin Scheglov,
Google, Inc.
Re: JFace [message #775338 is a reply to message #775292] Thu, 05 January 2012 14:54 Go to previous message
Eric Clayberg is currently offline Eric Clayberg
Note that if you use the SWT/JFace project wizard that comes with WB or the Plugin/RCP wizard that comes with Eclipse, JFace will already be on the classpath. If you create the project manually or use the simple Java project wizard, it is up to you to properly configure the classpath with things like JFace.
Previous Topic:How to avoid default container for JFRAME and for all others also
Next Topic:JList data binding not working.
Current Time: Sun May 19 13:00:58 EDT 2013
Powered by FUDForum. Page generated in 0.01479 seconds
