Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Project meta data is out of date for tools.buckminster
[buckminster-dev] Project meta data is out of date for tools.buckminster [message #775002] Thu, 05 January 2012 00:00
Eclipse User
Henrik, Thomas,
Projects are required to keep meta data up to date using the MyFoundation
Portal (http://portal.eclipse.org/). The following problems were found
with this project's meta-data:
* The date for release "Indigo SR1" is in the past, but the release is not
marked as completed. If it is completed, it should be marked as completed;
if it has been postponed, it should be given a new target date.
Previous Topic:Buckminster sample cqueries seem to be missing
Next Topic:[buckminster-dev] (no subject)
Current Time: Tue May 21 23:12:01 EDT 2013
Powered by FUDForum. Page generated in 0.01570 seconds
