Home » Eclipse Projects » XML Schema Definition (XSD) » No targetnamespace set for local elements inside complextype
No targetnamespace set for local elements inside complextype [message #77496] Thu, 19 March 2009 07:33 Go to next message
Bhuvan  is currently offline Bhuvan
Member
I have defined a complextype in an wsdl inside <types> section under
schema, as below :
test.wsdl
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<wsdl:definitions xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:tns="http://www.example.org/test/"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" name="test"
targetNamespace="http://www.example.org/test/">
<wsdl:types>
<xsd:schema targetNamespace="http://www.example.org/test/">
<xsd:complexType name="ct1">
<xsd:sequence>
<xsd:element name="ele1" type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
</wsdl:types>
</wsdl:definitions>
Now i am using below code snippet :
String sourceLoc = "C:\\test.wsdl";
File file1 = new File(sourceLoc);
final ResourceSet resourceSet = new ResourceSetImpl();
final Resource res1 =
resourceSet.getResource(URI.createURI(file1.toURI().toString ()), true);
WSDLResourceImpl wsdlr = (WSDLResourceImpl)res1;
Definition definition = wsdlr.getDefinition();
Types types = definition.getETypes();
XSDSchema schema = (XSDSchema) types.getSchemas().get(0);
XSDComplexTypeDefinition complexType = (XSDComplexTypeDefinition)
schema.getTypeDefinitions().get(0);
final XSDElementDeclaration element =
(XSDElementDeclaration)((XSDModelGroup)((XSDParticle)complex Type.getContent()).getContent()).
getContents().iterator().next().getContent();
System.out.println(element.getName());
System.out.println(element.getTargetNamespace());
So now when i get the targetNamespace for ele1 which is defined in complex
type "ct1" then it is returnd as "null", where as it should be
"http://www.example.org/test/".
This case works fine when we have this schema defined in an XSD file and
process it ??
It seems there is something wrong in the "XSDSchema" which is returned by
wsdl "Definition".
Thanks and best regards,
Bhuvan Mehta
Re: No targetnamespace set for local elements inside complextype [message #77519 is a reply to message #77496] Thu, 19 March 2009 08:17 Go to previous message
Ed Merks is currently offline Ed Merks
Bhuvan,
Comments below.
Bhuvan wrote:
> Hello,
> schema, as below :
> test.wsdl
> <wsdl:types>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> </wsdl:types>
> </wsdl:definitions>
> complex type "ct1" then it is returnd as "null", where as it should be
No, local element declarations by default have form="unqualified" and
the schema itself by default has elementFormDefault="unqualified" so
unless you take explicit action to set one of these two things to
"qualified" the element will be unqualified and hence will have null
target namespace.
> and process it ??
It will work the same way or are you asserting otherwise?
> by wsdl "Definition".
No, I think your expectations are incorrect.
> Bhuvan Mehta
Re: No targetnamespace set for local elements inside complextype [message #604133 is a reply to message #77496] Thu, 19 March 2009 08:17 Go to previous message
Bhuvan,
Comments below.
Bhuvan wrote:
> Hello,
> schema, as below :
> test.wsdl
> <wsdl:types>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> </wsdl:types>
> </wsdl:definitions>
target namespace.
> and process it ??
> Bhuvan Mehta
Previous Topic:No targetnamespace set for local elements inside complextype
Next Topic:How to access the ID of a XSDComponent
Current Time: Sat May 25 01:30:36 EDT 2013
Powered by FUDForum. Page generated in 0.02228 seconds
