Home » Language IDEs » PDT » Editor stop working
Editor stop working [message #768654] Tue, 20 December 2011 09:50 Go to next message
Missing name Missing name is currently offline Missing name Missing name
hi, i have a very strange problem.
while i was editing a php file, my keyboard started to act weird: i was typing a letter and i saw another one.
so i closed eclipse and reopened it.
but... this is what i get:
Could not open the editor: Editor could not be initialized.
::::LOG FILE::::
java.lang.Error: Error: could not match input
	at org.eclipse.wst.xml.core.internal.parser.XML10Names.zzScanError(XML10Names.java:473)
	at org.eclipse.wst.xml.core.internal.parser.XML10Names.isValidXML10Name(XML10Names.java:588)
	at org.eclipse.wst.xml.core.internal.parser.XML10Names.isValidXML10Name(XML10Names.java:271)
	at org.eclipse.wst.xml.core.internal.provisional.NameValidator.isValid(NameValidator.java:50)
	at org.eclipse.wst.xml.core.internal.document.DocumentImpl.isValidName(DocumentImpl.java:1015)
	at org.eclipse.wst.xml.core.internal.document.DocumentImpl.checkTagNameValidity(DocumentImpl.java:258)
	at org.eclipse.php.internal.core.documentModel.dom.DOMDocumentForPHP.createElement(DOMDocumentForPHP.java:44)
	at org.eclipse.wst.xml.core.internal.document.XMLModelParser.insertStartTag(XMLModelParser.java:1482)
	at org.eclipse.wst.xml.core.internal.document.XMLModelParser.insertStructuredDocumentRegion(XMLModelParser.java:1510)
	at org.eclipse.wst.xml.core.internal.document.XMLModelParser.replaceStructuredDocumentRegions(XMLModelParser.java:2354)
	at org.eclipse.wst.xml.core.internal.document.DOMModelImpl.internalSetNewDocument(DOMModelImpl.java:661)
	at org.eclipse.wst.xml.core.internal.document.DOMModelImpl.setStructuredDocument(DOMModelImpl.java:936)
	at org.eclipse.wst.sse.core.internal.model.AbstractModelLoader.createModel(AbstractModelLoader.java:127)
	at org.eclipse.wst.sse.core.internal.FileBufferModelManager.getModel(FileBufferModelManager.java:725)
	at org.eclipse.wst.sse.core.internal.model.ModelManagerImpl._getModelFor(ModelManagerImpl.java:638)
	at org.eclipse.wst.sse.core.internal.model.ModelManagerImpl.getModelForEdit(ModelManagerImpl.java:1371)
	at org.eclipse.wst.sse.ui.StructuredTextEditor.tryToGetModel(StructuredTextEditor.java:1979)
	at org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(StructuredTextEditor.java:1919)
	at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.doSetInput(PHPStructuredEditor.java:2332)
	at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3200)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
	at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759)
	at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:756)
	at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2642)
	at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3218)
	at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3245)
	at org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredTextEditor.java:2595)
	at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init(PHPStructuredEditor.java:1199)
	at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:828)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
	at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
	at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
	at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
	at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
	at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
	at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
	at org.eclipse.dltk.internal.ui.editor.EditorUtility.openInEditor(EditorUtility.java:415)
	at org.eclipse.dltk.internal.ui.editor.EditorUtility.openInEditor(EditorUtility.java:177)
	at org.eclipse.php.internal.ui.actions.OpenActionUtil.open(OpenActionUtil.java:54)
	at org.eclipse.php.internal.ui.actions.OpenAction.run(OpenAction.java:177)
	at org.eclipse.php.internal.ui.actions.OpenAction.run(OpenAction.java:151)
	at org.eclipse.php.internal.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:190)
	at org.eclipse.php.internal.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:168)
	at org.eclipse.php.internal.ui.actions.PHPExplorerActionGroup.handleOpen(PHPExplorerActionGroup.java:168)
	at org.eclipse.dltk.internal.ui.scriptview.ScriptExplorerPart$4.open(ScriptExplorerPart.java:677)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
What's happening?
I can't open that file anymore, but i still edit the others
Re: Editor stop working [message #773773 is a reply to message #768654] Mon, 02 January 2012 08:52 Go to previous messageGo to next message
dominik is currently offline dominik
> What's happening?
Probably You have some syntax error in this file. Open it with notepad or in
Eclipse as text file (open as) and try to find issue, correct and then use
Eclipse in normaln mode.
Of course eclipse should open file and show error, but some modules are buggy.
/dmc
Re: Editor stop working [message #774653 is a reply to message #773773] Wed, 04 January 2012 05:46 Go to previous message
hi, i found the glitch!
the editor starts to work buggy when i have a code like that:
<?php if($test): ?>
<div>
   some stuff
</div>
<?php endif; ?>
when i try to add anything inside the div element, everything screw up...
i hope this helps
Previous Topic:Changing $_SERVER values on the fly.
Next Topic:indigo + pdt Text Hover is slow
Current Time: Sat May 25 13:46:39 EDT 2013
Powered by FUDForum. Page generated in 0.08689 seconds
