Home » Eclipse Projects » Hudson » ssh access to hudson.eclipse.org
ssh access to hudson.eclipse.org [message #774234] Tue, 03 January 2012 10:12 Go to next message
vincent lorenzo is currently offline vincent lorenzo
Hi all,
I'm working on the Papyrus build, and I would like to know if there is a way to access to my build configuration with ssh. This access would allow to copy easily the scripts declared in the build configuration to save them.
Re: ssh access to hudson.eclipse.org [message #775154 is a reply to message #774234] Thu, 05 January 2012 08:12 Go to previous message
Duncan Mills is currently offline Duncan Mills
Vincent - In general Hudson terms, the way to approach this requirement is to use the Hudson Rest API.
The Rest API allows you to fetch and Put a configuration directly without needing shell access onto the machine.
Thus you can use the URL https://hudson.eclipse.org/hudson/job/<your job>/config.xml to get the configuration
See also:
https://hudson.eclipse.org/hudson/job/<your project>/api for more info.
The Hudson setup at Eclipse is secured so you will need to authenticate with your committer id
Hope that helps
Duncan Mills
Eclipse Hudson team
Previous Topic:Building Eclipse Rich Client Applications using Hudson
Next Topic:Hudson Users Mailing List
Current Time: Wed May 22 15:20:10 EDT 2013
Powered by FUDForum. Page generated in 0.01846 seconds
