Home » Eclipse Projects » WindowBuilder » Unable to get Window Builder to Work after Install(Window Builder Issue)
Unable to get Window Builder to Work after Install [message #773342] Sun, 01 January 2012 03:47 Go to next message
Kevin Ellsworth is currently offline Kevin Ellsworth
I just installed Windowbuilder on new install of Eclipse Helios that I just downloaded and subsequently installed Windowbuilder.
The installation appeared to have gone correctly and did not see any bugs.
However, I'm trying to get Windowbuilder started, I click "File>New>Other" then from "New" screen I scroll down and select "WindowBuilder". Then I click "Swing Designer" and then click "JFrame". Then I click "Next".
Here's where nothing seems to work. In the form labeled "New JFrame", I see the error message "Source folder name is empty". I then click "Browse" and a disabled form comes up labeled "Source Folder Selection". But in this form it is disabled and I don't see a navigation tree to select a sub-folder on my Windows 7 Laptop. Also, a little red icon is at bottom with shows "No entries available" and the "Ok" button is disabled.
I can only click "Cancel" which takes me back to the "New JFrame" form.
The "Next" and "Finish" button are disabled and I can't move forward.
Please help and let me know how I can get WindowsBuilder working.
Thanks.
Re: Unable to get Window Builder to Work after Install [message #773349 is a reply to message #773342] Sun, 01 January 2012 04:13 Go to previous messageGo to next message
Nevermind. I realize I have to create a project first. Once I created the project I'm now able to see Windows Builder in action.
Re: Unable to get Window Builder to Work after Install [message #773437 is a reply to message #773349] Sun, 01 January 2012 11:03 Go to previous message
Eric Clayberg is currently offline Eric Clayberg
I would recommend the docs in a case like this.
Previous Topic:Support for e4 ?
Next Topic:Eclipse Hangs when I try to modify JTable model
Current Time: Sat May 25 17:41:46 EDT 2013
Powered by FUDForum. Page generated in 0.01656 seconds
