Home » Eclipse Projects » Virgo » Console in virgo 3.0.2
Console in virgo 3.0.2 [message #770129] Fri, 23 December 2011 07:21 Go to next message
Vladimir Glushak is currently offline Vladimir Glushak
As far as I understand, "vsh" console has been replaced in 3.0.2 release with new gogo console.
Previously, on virgo 2.x "vsh bundle list", return list of ~100 bundles for my application server.
Currently on virgo 3.0.2 "gogo:lb" or "bundles" commands output only list of 47 kernel bundles, the same count output equinox "ss" command. But my application is up and running in this container. How to get list of user bundles, that are running?
Re: Console in virgo 3.0.2 [message #770132 is a reply to message #770129] Fri, 23 December 2011 07:28 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn Normington
It sounds like you are using the kernel shell on port 2401 instead of the user region shell on port 2501, which still includes the vsh command. Please refer to the User Guide for details of how to enable the user region shell.
Re: Console in virgo 3.0.2 [message #770141 is a reply to message #770132] Fri, 23 December 2011 08:03 Go to previous message
Rather confusing solution. Thanks a lot for help! I missed this two lines in documentation Smile
Previous Topic:listener (bind-method and unbind-method) bundle behavior when listened service leaves
Next Topic:3.0.1 failed to build
Current Time: Mon May 20 00:44:11 EDT 2013
Powered by FUDForum. Page generated in 0.01767 seconds
