Home » Eclipse Projects » scout » Scout vs Riena platform (Few questions related to Scout Project)
Scout vs Riena platform [message #769941] Thu, 22 December 2011 19:06 Go to next message
narayan  is currently offline narayan
I just found scout project and watched your demo. I have few questions and can anyone more experienced in scout project help me to answer these questions?
I am just wondering does scout project and eclipse Riena platform has overlapping functionality or scout project uses Riena under the hood to provide rapid application development.
Do you have any plan of supporting window builder to design the UI?
Does scout project planning to add support to E4 dependency injection and programming model?
Re: Scout vs Riena platform [message #770046 is a reply to message #769941] Fri, 23 December 2011 02:12 Go to previous messageGo to next message
Christian Campo is currently offline Christian Campo
Scout and Riena have two independant codebases and none of them is based on the other. Sme of the functionality is similar, though the approach to get is very very different.
Chrstian campo
Projectlead Riena
Re: Scout vs Riena platform [message #770150 is a reply to message #769941] Fri, 23 December 2011 08:25 Go to previous messageGo to next message
Bertin Kiekebosch is currently offline Bertin Kiekebosch
did you notice this discussion, search for Proposal Feedback [message #579508]‎ by Martin Lippert in the Scout Forum. Its about Riena vs Rap.
and Scout and E4? [message #531521] by Werner Keil
I don't know if windowbuilder will be supported, but from my experience, building nice looking forms is easy with Scout. (compared to plain SWT or Swing).
Regards Bertin
Re: Scout vs Riena platform [message #770177 is a reply to message #770150] Fri, 23 December 2011 09:43 Go to previous messageGo to next message
Jeremie Bresson is currently offline Jeremie Bresson
Hier the links to the mentionned post:
* [message #579508]‎ Proposal Feedback
* [message #531521] Scout and E4?
Re: Scout vs Riena platform [message #770418 is a reply to message #769941] Sat, 24 December 2011 01:35 Go to previous message
Here my answers to the points you mentioned:
Eclipse Scout vs Eclipse Riena
The answers given by the project leader of Riena is correct. I think both projects have their strength and weakness. A comparison could be usefull.
Scout form builder (based on window builder)
Window builder is a very good framework. An implementation of a Scout Form Builder based on this framework would be great. This topic is often asked on the conferences where scout is presented. A prototype has been developed, but it isn't advanced enough for a public presentation.
I think the "Outlook e4" section in the scout proposal is still valid.
It would be great to have Scout RT based on these concepts.
For now Scout has its own application model and uses its own concepts to render the same UI with different libraries, because it started before E4.
A move to Eclipse 4 (using its DI and model) is a big move, since a lot of the runtime code needs to be changed.
Previous Topic:AbstractCalendarField
Next Topic:Scout SWT UI improvement for Mac OS X
Current Time: Tue Jun 18 02:18:53 EDT 2013
Powered by FUDForum. Page generated in 0.02017 seconds
