| Problem with Eclipse tomcat server context getting stripped [message #769703] |
Thu, 22 December 2011 09:59  |
Ari Messages: 1 Registered: December 2011 |
Junior Member |
Hello all, I had a long-running issue in Eclipse Helios. and after getting a new computer, I realized I had same issue pop up a week after using Indigo, and was wondering if i can look at changing any settings to fix this as not sure what I could have done to get this behavior ...
Basically when I start up my Eclipse tomcat server, the <Context.../> it publishes in the server.xml used to look like this (the one published in C:\dev\workspace\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp4\conf):
<Context docBase="C:\dev\workspace\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp4\wtpwebapps\my_app" path="/my_app" reloadable="true" source="org.eclipse.jst.j2ee.server:my_app">
<Resource auth="Container" driverClassName="oracle.jdbc.OracleDriver" factory="oracle.jdbc.pool.OracleDataSourceFactory" maxActive="100" maxIdle="30" maxWait="1000" name="jdbc/our_db"
user="our_username" password="our_password" removeAbandoned="true" type="oracle.jdbc.pool.OracleConnectionPoolDataSource"
url="jdbc:oracle:thin:@db.example.com:our_port:db_name" />
</Context>
... but now it looks like this:
<Context docBase="C:\dev\workspace\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp4\wtpwebapps\ROOT" path="" reloadable="false"/><Context docBase="C:\dev\workspace\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp4\wtpwebapps\my_app" path="/my_app" reloadable="true" source="org.eclipse.jst.j2ee.server:my_app"/>
Basically I lose all my database info in my_app's Context, plus it adds the "ROOT" context in the published server.xml, and my server doesnt doesnt start up correctly as a result of that ... I usually just put a comment above my Eclipse server.xml (the one in C:\dev\workspace\eclipse-workspace\Servers\my_app - Tomcat v6.0 Server at localhost-config) with my <Context.../> xml again and that doesn't get stripped out... then in the server.xml published in C:\dev\workspace\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp4\conf, I copy whats in that comment and overwrite the stripped down version Eclipse creates, and quickly restart the tomcat server in Eclipse.
Its a pain as another simple tomcat project I setup in Eclipse started having same issue, so was wondering what I can do to solve as its a bit of hassle to start up the server each time [the good Context i copy manually will always get stripped out when project auto-published i think, so i have to re-copy,save,restart server in Eclipse].
Thanks!,
Ari
| Re: Problem with Eclipse tomcat server context getting stripped [message #769839 is a reply to message #769703] |
Thu, 22 December 2011 14:27  |
Russell Bateman Messages: 2707 Registered: July 2009 Location: Provo, Utah, USA |
> [snip]
> Thanks!,
> Ari
This is rather more an Eclipse web tools forum question. You'll get much
more and better help there.
FUDForum. Page generated in 0.01695 seconds
