Home » Eclipse Projects » Rich Client Platform (RCP) » Change view tab color in a product.
Change view tab color in a product. [message #461973] Fri, 19 January 2007 08:08 Go to next message
Eclipse User
Originally posted by: susan_Ross.hotmail.com
When you change tab color in Eclipse preferences ( window > Preferences...
> General > Appearance > Color and Fonts > View and Editor Folders) it
adds in the file:
<workspace> .metadata\.plugins\org.eclipse.core.runtime\.settings\org.ec lipse.ui.workbench.prefs
the following preferences:
org.eclipse.ui.workbench.ACTIVE_TAB_BG_START=255,128,64
org.eclipse.ui.workbench.ACTIVE_TAB_BG_END=255,255,0
How can I set this preferences programatically in my product?
I also tried to set both following options in plugin_customization.ini
file but it neither worked:
org.eclipse.ui.workbench/ACTIVE_TAB_BG_START=125,179,114
org.eclipse.ui/ACTIVE_TAB_BG_START=125,179,114
It is very important, can someone help me? Please
NOTE: I need to set this options programming because It depends of
different configurations.
Best Regards,
Susan
Re: Change view tab color in a product. [message #769791 is a reply to message #461973] Thu, 22 December 2011 12:10 Go to previous message
Christophe Moine is currently offline Christophe Moine
you should try something like:
workbench.getThemeManager().getCurrentTheme().getColorRegistry()
					.put(IWorkbenchThemeConstants.ACTIVE_TAB_BG_END, ....);
I hope that helps.
Previous Topic:Executing a command twice fails
Next Topic:Changed View ID, now it never displays
Current Time: Mon May 20 11:16:36 EDT 2013
Powered by FUDForum. Page generated in 0.01857 seconds
