It´s my first time working with org.eclipse.ui.menus menuContribution and
org.eclipse.ui.commands
to cause a wizard page to be executed. A Handler class set as defaultHandler
is responsible for executing the
command mentioned above. My implementation works for the first execution.
But executing it twice
it fails with the following exeception:
org.eclipse.core.commands.NotHandledException: There is no handler to
execute for command
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:485)
org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Any advice on what the problem is?
Thanks in advance.
Never mind, issue resolved. I made an implementation mistake which is rather
specific to my problem domain, would rather not go into further details
about it.
execute for command
Thanks in advance.
